Stock front brake line length?
Old Nov 22, 2013 | 09:05 PM
What is the stock front brake line length? Believe me I searched and could not find any post with the exact length for the stock brake lines.
I found some Goodridge steel brake lines that came off a SV650 for $30. The guy is going to measure the lines for me this Sunday to see if they will fit the Superhawk. I'm hoping they will fit and maybe have a little slack in 'em, just in case I go with different bars.
Old Nov 22, 2013 | 09:11 PM
KCCO's Avatar
Are you looking for the straight line length or including the length with the splitter block?
Old Nov 22, 2013 | 09:15 PM
Don't most aftermarket companies do without the splitter and just run two lines off the master? Just looking for the length from the master cylinder to the caliper. I would check my bike, but can't for several days right now.
Old Nov 22, 2013 | 09:28 PM
KCCO's Avatar
Give me a few minutes and I'll run out to the garage.... brb
Old Nov 22, 2013 | 09:33 PM
KCCO's Avatar
With the bike sitting on the ground, with superbike bars, you are looking at 24" from bolt to bolt with a little play room, does this help?
Old Nov 22, 2013 | 09:38 PM
Yes it does. It is exactly the information I was looking for. You rock man, thank you!
Old Nov 22, 2013 | 09:41 PM
Almost forgot, which caliper did you measure to? The furthest away from the master cylinder?
KCCO's Avatar
No problem, I would guess anything over 26" should be ok, and obviously longer is ok as long as its not ape hanger longer
killer5280
Jan 15, 2010 04:34 AM
roisman
Mar 25, 2008 10:43 AM
spdrcr
Oct 26, 2007 07:35 AM
cliby
Mar 8, 2007 06:13 AM
CNI Dawg
Nov 6, 2005 06:59 PM
