Stock front brake line length?
What is the stock front brake line length? Believe me I searched and could not find any post with the exact length for the stock brake lines.
I found some Goodridge steel brake lines that came off a SV650 for $30. The guy is going to measure the lines for me this Sunday to see if they will fit the Superhawk. I'm hoping they will fit and maybe have a little slack in 'em, just in case I go with different bars. |
Are you looking for the straight line length or including the length with the splitter block?
Don't most aftermarket companies do without the splitter and just run two lines off the master? Just looking for the length from the master cylinder to the caliper. I would check my bike, but can't for several days right now.
Give me a few minutes and I'll run out to the garage.... brb
With the bike sitting on the ground, with superbike bars, you are looking at 24" from bolt to bolt with a little play room, does this help?
Yes it does. It is exactly the information I was looking for. You rock man, thank you!
Almost forgot, which caliper did you measure to? The furthest away from the master cylinder?
No problem, I would guess anything over 26" should be ok, and obviously longer is ok as long as its not ape hanger longer
