showa race shock
Old Dec 30, 2006 | 01:02 PM
sean-emmett's Avatar
sean-emmett is on a distinguished road
showa race shock
hi guys
im in the uk and got myself a showa race shock off ebay that was listed as a race shock off some guys firestorm race bike.
anyway i have measured it all up next to a standard firestorm shock and all is the same. only i cant find no info on it. it has a remote compression cylinder that needs to be pumped up yet i dont know what psi to pump it to.
any info whould be great.
thanks
mark
Old Dec 30, 2006 | 01:57 PM
It should already be pressurized. It is pressurized with nitrogen only, and should be done by a good suspension service center. Normal is about 150-175 psi.
Old Dec 31, 2006 | 08:15 AM
hi,
the remote cylinder has a valve on it that is the same size for a foot pump or bike pump.
does it not get pumped up with just air? so i would have to have it sent off to a service centre?
thanks
mark
Old Dec 31, 2006 | 10:26 AM
No, it is NOT air. It's Nitrogen, and a special fitting has to be used to pressurize it. One little puff of gas is like 25 psi because the resorvoir is so small, so your regular air pump or even air chuck won't work. Nitrogen is used because its volume changes less with temperature, therefor pressure will change less with temperature, for the same volume. It is also less reactive than air (oxygen, humidity, etc).
Old Dec 31, 2006 | 11:28 AM
JamieDaugherty's Avatar
You can put air in there but only as a temporary test. I do this to check for leaks, I'll put 100psi of air in the reservoir overnight and check for leakage the next day. If everything is ok I release the air and put Nitrogen in. Contrary to a previous post, the typical is either 175 psi or 250psi.
Do you have any pictures of the shock? It sounds like a pretty rare item.
Old Dec 31, 2006 | 04:06 PM
I guess it depends on the shock brand, as Elka runs about 150# and Fox 175#. I'll be honest, I'm not sure about Showa or Ohlins. It really depends how close the shock is valved to being on the verge of cavitation. The closer it is, the higher the pressure needs to be to prevent cavitation.
Old Dec 31, 2006 | 07:44 PM
FYI - Fox recommends 250psi in all of their shocks. I don't know about "back in the day" but in the past 10 years that I've dealt with them it's always been the same. The pressure that the Elka's have seems low, I wonder why it's that way. Less seal drag maybe.
Old Jan 1, 2007 | 08:53 AM
We measured 150 in the Fox when recieved. Dyno'd with no obvious signs of cavitation. We put 175 back in and had a smoother graph, though no cavitation once again.
E.Marquez
Oct 10, 2016 04:09 AM
JPP
May 23, 2012 05:59 PM
nykuryu
May 8, 2011 05:57 AM
comedo
May 6, 2010 02:44 PM
yaseric
Oct 6, 2004 09:39 AM
