Saddlebags and High Mounts
I haven't taken a road trip since I mounted up the Leo Vince High mount exhaust pipes, so I need to get this figured out by Wednesday. Is there a problem with the exhaust contacting the bags? I don't remember the cans getting all that hot, no like the pipes; but how hot is too hot? Does anybody use saddlebags with highmounts? Are there special precautions that I can take? Is there a heat blanket type material that I could use between the two? I am going to go conduct a test now, to see how hot the cans get, but would like to hear what others have to say. I believe the bags I have are the Cortech Sport or TourMaster Sport bags.
I'm curious to know what you come up with. I do know that thermo tec heat barrier works wonders for blocking heat. How you might attach it to the bags is up to you but I used it inside a lower fairing and was extremely impressed with how well it worked. I too have the same exhaust (in carbon-forget what you said yours was) but have never tried using bags with it. Then again my bike's been in modification purgatory for the better part of two years so I haven't tried alot of things lately with it
I have the Leo Vince Aluminum/Stainless High Mounts. They are a bit higher than the Jadine and other Highmounts that I have seen. They almost touch the rear cowl. I have the bike warming up outside. I will let you know how hot they get. There appears to only be a small section where they would actually touch. I could probably just put duffel bag or my computer bag on the seat under the straps so the saddle bags would sit higher.
Is thermo tech available at local auto supply stores?
My LV CARBONS are only warm to touch even at idle. I wouldn't trust a bag touching any metal cans tho' especially SS ones.
How about some of that automotive underhood insulation applied to the bags? I would trust that with CF cans for sure but would test metal cans.
I also found the mounting the bags backwards helps as well, although I am not sure which way they are supposed to go anyways!
I may try to make up a pad (like a horse blanket) to go under the bags and boost them up since I would rather have my back pack on top of the saddle bag straps. A tip I recently read is to use those non-slip pads that you put in your shelves or under area rugs. It may help protect the paint from vibration induced chaffing.
senecagreen
Aug 21, 2006 10:12 PM
