Is replacing the brake pads fairly easy?
Old Jun 22, 2006 | 03:47 PM
seattlesucks's Avatar
seattlesucks
Is replacing the brake pads fairly easy? I know it's easy on most bikes... does that hold true with the superhawk? I'm going to be doing it on Saturday... prolly OEM on the rear and EBC HHs on the front.
I'm new to working on my own bike. How many brake pads am I going to need for the stock calipers?
Old Jun 22, 2006 | 04:07 PM
superhawk22's Avatar
Front needs 2 for each side, (2 sets total), rear is just 2, (1 set), and they're really easy to change. Do you have a manual? If not there's one you can download on here somewhere you can figure it out just makes it easier.
Old Jun 22, 2006 | 04:59 PM
marmaladedad's Avatar
Hmm?
Very easy. I find it's easiest when the calipers are removed (two 8mm allen screws on each side). Then remove the small mini-screw with a flat-head screwdriver, and the allen screw that lies underneath that. This releases pressure on the pad clip, and the old pads should slide right out.
Before you throw the old pads away, I find it helps to use them to push the pistons back into the caliper. This gives you a bit more breathing room with the new pads. Install the new pads, line up the pad clip and allen screw that puts tension on the pad clip, etc.
Old Jun 22, 2006 | 05:08 PM
nineighthawk's Avatar
nineighthawk
Where do you live? .. maybe I can come over and supervise
I don't have too much going on this Saturday.
Old Jun 22, 2006 | 10:18 PM
Scumbag's Avatar
Scumbag is an unknown quantity at this point
car show in greenwood.........hey I am gunna change my pads soon too....maybe make it a seattle pad party
Old Jun 22, 2006 | 10:57 PM
RonVTR's Avatar
RonVTR
Can I offer my assistance... I've changed pads several times. And I'm going to be in Seattle (Shorline) this weekend. Late Sat morning works best for me as I'll be down by GreenLake picking up some pads for the Guzzi.
You'll need tools, fresh DOT 3 or 4 fluid and a piece of hose to bleed the brakes. Oh also an old turkey baster... Really
Old Jun 23, 2006 | 09:50 AM
Scumbag's Avatar
your headed down to the guzzi place down on aurora?.....met those folk.....good people.....
that guy there is a guzzi god...haha
Old Jun 23, 2006 | 12:14 PM
seattlesucks
Is there a specific size I need, or is it a one size fits all deal?
Old Jun 23, 2006 | 01:20 PM
For?
Old Jun 23, 2006 | 01:49 PM
Hmm?
I'm assuming you mean brake pads? There are Superhawk-specific pads made by EBC. I believe the part # for the front is FA187HH.
AJK
Sep 11, 2008 06:17 PM
F1 Fan in Nascar Land
Feb 2, 2007 07:42 PM
Otto Man
Jan 6, 2007 01:36 PM
ZZRsouth
Jun 21, 2006 07:40 PM
mikstr
Jun 16, 2006 07:36 AM
