Rear wheel slop?
The ghetto/racetrack fix is to get about $2 worth of aluminum flashing from home depot and bend it over the rubber to shim them out. The rubber will still work its just a bit squished.
This is the quick fix but yeah long term you need to replace them. Its bad for the bike to have "wheel confusion" which is the slop you mention between on the power or engine braking. It creates harsh impacts where there should not be those.
Sounds good guys! Figured the slop wasnt good at all.
Now I have to sort out the surging when riding. Im thinking the carbs need a going through. Steady throttle and the bike surges like im giving it small inputs on the throttle. Also when I crank into it at say 4k to 6-7k there is a huge bog and dead zone.
I figured its either the carbs or the gas not getting to the carbs.
I have to get the tank off and check the airbox and all.
The vac line for the diaphragm looked a bit rotted so I wonder if its just fuel starved from that?
For the price ill change out the fuel line and vac lines and go from there
