rc51 front end price
Old Mar 24, 2015 | 06:41 AM
Bearshawk's Avatar
what you all of you fellas pay for a complete RC51 front end... there is one on ebay, im sure some of you have seen/watching it, going for 1200 bucks
is that really a going price for a straight setup? sp1 to sp2 difference in value?
im talking, clipons, triples, brakes, legs, wheel, rubber
Old Mar 24, 2015 | 09:38 AM
That sounds expensive to me. The issue with the RC51 stuff is that there are not many of them so they are slipping into the "collectors items" prices.
You can get a cbr1000rr set up for much less since they are plentiful.
For that matter many other front ends are less than half that. FWIW I got my CBR 600RR front complete for $400 and IMHO its a better setup. This is cheap but just shows your options.
It even uses the same bearings! I swapped to tapered rollers but still.
Old Mar 24, 2015 | 09:40 AM
That's high, for me anyway. If its an SP2 it would command a higher price just because of the wheel. Which have become rare and sought after. Also at that price I would expect the forks to have a fresh rebuild with springs and valves for my weight and riding style. I want the moon too...
IIRC the bottom triple/stem won't work in the SH. Take a look at the front end swap guide to sort out the compatibility issues. If you end up getting parts you don't need, that's dollars wasted.
Old Mar 24, 2015 | 10:31 AM
Bearshawk's Avatar
i have read the fork swap guide and i go back and forth about the swap....
i need new seals in my stock forks and i did RT springs last year but NOT valves and was only mildly happy with the results.
IF i stick with stock i will have to have them rebuilt and add valving.
i really love USD forks... and having moved to kansas where there are tracks to play on i think the adjustability in RC51 forks or any other fork for that matter would be good especially since i DO plan on track days
if i can get a SP1 front end for anything near what it would cost to rebuild/revalve my stockers, i feel that it would be worth it + i could sell my RC51 brake swap here easily, and the bar risers...and throttlemeister
Old Mar 24, 2015 | 05:08 PM
What year CBS600RR? Did you loose steering lock and were there fairing contact issues?
Old Mar 25, 2015 | 08:46 AM
Skokie I have 2 VTRs. One has the 1000rr front end. You loose some steering lock due to them being quite a bit wider. I didn't trim fairing but filed down the stops.
The 600rr front end I think is 08ish but isn't mounted yet, just installed roller bearings on it. It is way narrower than the 1000 unit. Similar to the VTRs size so don't expect to lose much lock.
Will post up when its on, should be soon.
Old Mar 25, 2015 | 12:21 PM
I guess you could say it is being that it wasn't simply an asking price, it actually sold for that. One could probably do a little better buying the parts separate here and there when good deals come up but when you itemize all the parts it's not really that crazy...
HRCA#1
Jul 3, 2013 10:07 AM
Quickling
Jun 11, 2009 09:30 PM
gps
Aug 25, 2007 01:50 PM
Dominion
Jul 23, 2007 09:52 AM
bigbob65
May 14, 2007 12:22 PM
