Quick pair question so i can ride
Old Dec 29, 2012 | 11:23 AM
0317Hawk's Avatar
0317Hawk is on a distinguished road
Message removed.
Old Dec 29, 2012 | 01:39 PM
twist's Avatar
Originally Posted by 0317Hawk
Just performed pair removal and want to make sure I am supposed to cap every vent line connecting to the bottom of the air box. Also, can I cap where the front breather hose connects to the front of the engine at what I believe is the cylinder head cover? There is air coming out of that hose and also maybe a little oil or lubricant of some sort. Thanks
there is a full description in the knowledge base, https://www.superhawkforum.com/forum...-removal-9875/
The short answer is, that part I think you are referring to the PAIR reed valve. It allows unburnt fuel to be burnt off in the exhaust, (I'm sure someone will correct me if I am wrong). You need to remove that little housing with a hose on it, gently pull the little reed valve out, remove the little screw and turn the assembly over so the metal tab holds the reed closed. Plug the hose connection of the housing and reinstall, or you can order the block off plates, https://www.superhawkforum.com/forum...es-sale-18515/
0317Hawk
Dec 29, 2012 09:01 PM
98VTRrider
Dec 20, 2011 12:33 PM
uchi
Nov 2, 2009 06:03 PM
E.Marquez
Dec 31, 2008 01:44 PM
roadrun_fr
Aug 3, 2005 04:55 PM
