Questions with trailering my SH
Old Oct 12, 2004 | 07:18 PM
cdyer77's Avatar
cdyer77
First of all, you shouldn't "attack" the tie downs. What did they do to you? - Kiddin'
If you have a set of soft hooks you should just be able to put those on around the clip-ons and attach the tie downs to them. I highly recommend getting a set of soft hooks if you don't have them. Makes things alot easier. Besides they are cheap- $10-14 at any dealership.
You shouldn't have to take any plastic off the bike to trailer it.
Old Oct 13, 2004 | 07:26 AM
Random's Avatar
Random
Re: Questions with trailering my SH
Just wrap a rag or old shirt around the strap where it might contact the plastic. You shouldn't have to remove the plastic to "strap it down".
If you use a "canyon dancer" or similar "clip-on/handlebar" strap, slip a peice of PVC tubing over the grips to protect the grips/throttle. A friend of mine ripped his grips trailing his bike to a track day with one of those. While we were there, we saw several other guys who simply used 1.5" PVC piping slipped over the grips! Cheap and effective.
My question for you guys is regarding how tight you "tie down" the bike. From talking to guys at track days, I've found 2 "schools of thought".
One says that you should compress the front and rear suspension completely with the tie down straps, to prevent the bike from "hopping around".
The second, thinks that it's bad to bottom out your suspension like that, and reccomends that you only compress the suspension an inch or so, just enough to keep the straps in constant tension.
Anyone care to comment?
Old Oct 13, 2004 | 05:20 PM
faz's Avatar
faz
faz
nothing to add really, except that I have Helibars raisers and they say that tie downs should not be secured to their raisers. (we are not talking stock, just Helibars.)
Just thought I should drop this piece of info here as a heads up for future users.
Old Oct 13, 2004 | 08:20 PM
marmaladedad's Avatar
Hmm?
I use a Canyon Dancer harness for my bike, and it works fine. You do have to watch out for the throttle being twisted.
Do you have two-sided loop straps? You can use that to attach your tie downs and pull down on the lower triple to secure the bike.
Old Oct 15, 2004 | 03:27 PM
cdyer77's Avatar
cdyer77
I didn't mean to hook them directly onto the clip-ons themselves. I usually slide them all the way past the clip-on to the top triple clamp, and tighten them down from there. So they are actually around the end of the clip-on , where the pinch bolt is, and is actually pulling on the triple clamp and the end of the clip-on that bolts to the fork leg.
Hope that helps clear things up a little. It actually sounds much more confusing then it really is.
uchi
Oct 17, 2009 06:51 AM
macarthor
Apr 24, 2007 09:42 PM
supertwinSH
Apr 11, 2007 04:39 PM
Randman
Mar 29, 2007 08:19 PM
bluedog66
Mar 26, 2007 07:47 PM
