purchase advice
Old Feb 16, 2011 | 11:20 AM
Dudley's Avatar
Dudley is on a distinguished road
purchase advice
I'm looking at a 2002 Superhawk with 21250 miles. Yosh carbon cans and I think pipes. The bike has been down on the left side 1 time and has some road rash on the left mirror, faring, leading edge of the exhaust can. Also upgraded pads, steering damper installed and the PO removed the rear brake light switch and discarded it.
What should I be looking for on this unit?
Dudley
Old Feb 16, 2011 | 12:01 PM
skoshere's Avatar
usual Superhawk issues... ccts and R/R.... find one that hasnt been down and negotiate on that one...
Old Feb 16, 2011 | 12:14 PM
That's a weird thing to remove- sounds almost like one of those "My turn signals came off in the crash, but I didn't want them on there anyway" type of things.
The damper has been discussed a little bit lately, so that's why it's in my head, but you may want to see why the owner installed it. The reason is that this bike generally doesn't need a damper unless there are extreme geometry changes or some underlying suspension problem. It could just be that all of his buddies with a ducati bought one and he followed suit, but it could also be that the frame was tweaked/damaged,
Look for frame damage, test it and if it feels unstable at any speed be cautious, ask the owner about the bike...
Old Feb 17, 2011 | 01:23 PM
Dudley's Avatar
What needs to be checked/fixed with the cam chain tensioners? What is the R/R?
I did find another one, a '98 with 23000 on the clock only its 200+ miles from me.
Dudley
Old Feb 17, 2011 | 01:53 PM
I think finding a used bike that has been well taken care of is the prime target. If I were buying a Superhawk I would look for a senior rider who has decided to hang up his ranging bull. CCT's, Jets, Exhaust, if you're lucky some suspension could all be part of the package. If you truly want a Superhawk I would be tempted to run a "Superhawk Wanted" ad on CL. Lots of guys still watch the ads and there are "garage queens" to be had. Especially while Minnesota is still in the Tundra. I used to live in Deephaven.
Old Feb 17, 2011 | 01:54 PM
The OEM auto CCTs are known to fail randomly. Not in huge numbers, but enough to be a worry.
So either convert them to manual, or replace them with manual CCTs. Why? because if you are one of the unlucky tiny % that have a failure, the engine top end is toast for sure, and maybe the pistons too. It's cheap insurance to keep the motor lasting longer. ($6 + work for conversion, $110 + work for replace with APE branded ones)
The R/R (regulator rectifier, also called a voltage regulator) on basically all Honda bikes of this generation sucks. It will eventually fail. The 2002 will have an updated one vs the 98, that will get it a few more years service, but it too will eventually fail. It is best to replace it before it fails so that it doesn't take out other electrical things. A popular swap is to a Yamaha part that is MOSFET based rather than diode based, the Yamaha R/R is usually ~$40 off ebay and a very easy swap.
Old Feb 17, 2011 | 01:57 PM
PUSHrod's Avatar
Errr. . .R/R is 'regulator/rectifier'. I takes the current from the stator and flops it over three times to make it DC and under 15 volts. Provides the correct current to run the bike's electrics and charge the battery.
Cam chains drive the cam shafts, there is a unit on each of them that keeps them from flopping around inappropriately and causing expensive engine damage.
My suggestion is to hang out at bike night down to the local burger barn and make friends with a rider with gray hair who would be willing to show you where the rocks are to get you across the motorcycling stream you want to cross. A flesh and blood mentor will get you further, faster than a forum will. We like and welcome you here but there is only so much we can pass on knowing so little about you.
Old Feb 17, 2011 | 04:21 PM
OldGuy's Avatar
OldGuy is on a distinguished road
Were the valve clearances inspected/adjusted at 16,000 miles as specified by Honda? If not, having a shop do that can be a hefty chunk of change especially when added on to the purchase cost of the bike...something to consider. Does he have service records?
Old Feb 17, 2011 | 05:34 PM
Dudley's Avatar
I appreciate the help. A little about me. 65 yrs old, retired, MSF instructor, own three bikes now, have owned around 55, have a shop in my garage and do 99% of my maintenance. I, however, know absolutely nothing about the VTR 1000. Thats why my basic questions. I do not want to buy a pig in a poke.
Thanks
Dudley
Old Feb 17, 2011 | 07:58 PM
OK so the story is that you can swap out the cam chain tensioners pretty easily. The regulator is an easy swap too (you can buy aftermarket or use an R1 unit). There are threads on this forum about both (do a search) but this is a pretty bulletproof bike. Dont overpay since they are not expensive at the ages you are looking at. As always avoid wheelie squid owners.
Jakeson
May 20, 2013 06:52 PM
novamon
Jan 31, 2010 03:07 PM
ali_squidz
Jul 16, 2007 07:37 PM
Bigyella
Feb 1, 2007 05:34 AM
CTSmoto
Feb 24, 2006 05:45 AM
