POLL - Front & Rear Shock Setting
Old Apr 20, 2005 | 02:11 PM
ClevelandSuperhawkRumble's Avatar
about to adjust fronts and the shock in the back (the yellow one under my behind ) . was curious as to where you guys have your fron and rear settings at .
please state hieght/weight and how many turns out or in in front and notch setting for rear(1-7?) , notch 1 being the lowest notch(lowered the most) . also, please ad any mods you have done to the suspension (shims, etc) .
thanks
Old Apr 20, 2005 | 02:28 PM
L8RGYZ's Avatar
5' 8" & 180lbs
I'm still experimenting with the settings on my fully stock suspension.
For around town riding I usually run the front preload @ 3 rings, and rebound @ 1 turn from full hard; and the back preload at the 3rd position, with rebound @ 1 turn from full hard. On weekends I the same preload, but just do a half turn on front & rear rebound.
Old Apr 20, 2005 | 02:33 PM
Re: POLL - Front & Rear Shock Setting
ok, im gonna adjust mine. im 5'9 160 lbs, and am thinkin the 2nd would be a good notch for me but dont know anything about the front prel. and compr.
i do city drivin, and occassional twisties, but mostly crappy roads and bums and stuff common to Ohio's fine roadways
Old Apr 20, 2005 | 02:47 PM
marmaladedad's Avatar
Hmm?
I dunno if this helps, but I had Race Tech front springs (1.0kg/mm) in the forks and the rear shock was at 5 clicks.
I had planned on shimming the rear shock, but never got around to it.
Old Apr 20, 2005 | 03:04 PM
weight and height partner !
Old Apr 20, 2005 | 03:14 PM
Hmm?
Whoops! Sorry. 6'0, 240#
Old Apr 21, 2005 | 01:44 PM
ok, so who wants to let me borrow their spanner wrench no, seriously
Hawkrider
Apr 26, 2007 06:12 AM
Hawkrider
Mar 18, 2007 03:06 PM
Vincent
Apr 9, 2006 02:37 AM
Dutch
Jun 4, 2005 07:31 PM
