Pirelli Diablo tires lower the bike?
Old Jul 15, 2006 | 10:13 PM
mikecronis's Avatar
mikecronis
I had Diablo (standard, not Corsa) put on yesterday and now the bike leans over quite a bit when I put out the kickstand. Suggestions as to why? Same tire size (so I thought). Is Pirelli's standard measurement off?
Old Jul 15, 2006 | 10:18 PM
marmaladedad's Avatar
Hmm?
What was your previous tire? Some manufacturers have steeper profiles, even if they are listed as the same size (ie, 180/55-17).
Old Jul 15, 2006 | 10:48 PM
AC COBRA's Avatar
AC COBRA
i put in a set of diablo's and they are a shorter tire, there is more gap between the fender and tire in the front, and my speedo is off by more now then when it hah a 208 on the back
Old Jul 16, 2006 | 09:40 AM
If it leans over more on the sidestand, that means the tire profile is TALLER, not shorter. Think about the fact that new tires alone change the height at least 1/4" just from the fact that there is tread there now.
Old Jul 16, 2006 | 10:41 AM
HamsVTR's Avatar
HamsVTR
Don't worry, it'll turn in quicker too. Thing with new tires is to treat it like you're riding a completely different bike, because each tire will give the bike a different handling characteristic. Some may go as far as tweaking the suspension settings.
Old Jul 16, 2006 | 04:21 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
Ok that just sounds CRAZY that your speedo is off!!! i dont think that has anything at all to do with pirelli
Old Jul 16, 2006 | 07:29 PM
AC COBRA's Avatar
AC COBRA
how so, the tire is a little shorter than the 208, so at 80mph actual the bike will have to turn more rpm, thus making the speedo off a little more
with the newer 208 it was 4mph off, with the diablo its 6mph off
Old Jul 16, 2006 | 07:44 PM
SillyHawk's Avatar
if you say so....just thought you were being a little picky for an excellent tire overall.
Hotbrakes
May 5, 2009 05:48 PM
59burst
Jul 20, 2008 11:33 AM
AZZKIKER
May 14, 2007 08:44 AM
wormeater
Nov 11, 2006 02:07 PM
Shaggie
Feb 11, 2005 10:43 PM
