oil and clutch fluid change
Old Aug 11, 2011 | 11:55 AM
MikeMcW's Avatar
MikeMcW is on a distinguished road
Its probably a dead horse but I didn't find it when I did a quick search. When I change my oil is it a must that I also change the clutch fluid at the same time? I can do the oil change with out a problem. I have never bled anything so I don't have the bleeder. I want to do the oil change ASAP but wanted to make sure I didn't have to do both at the same time.
Old Aug 11, 2011 | 12:02 PM
Wicky's Avatar
no - they are separate systems. Have you downloaded the Honda VTR Service manual PDF linked in the workshop section.
All you need is a jam jar, hose and a ring spanner to bleed the clutch (add a large syringe to make it even easier).
Old Aug 11, 2011 | 12:31 PM
comedo's Avatar
A ring spanner is a box end wrench. An 8 mm. one, in this case. "Ring spanner" is the more poetic of the two names and is probably the term that Her Majesty would use.
Old Aug 11, 2011 | 12:53 PM
MikeMcW's Avatar
Thank you I wasn't sure what a ring spanner is. I will download that manual when I get home.
Old Aug 11, 2011 | 01:18 PM
Old Yeller's Avatar
yeah, the old fashioned way is to just open the valve at the slave cylinder, squeeze the clutch handle, close the valve, then release the handle.....about a hundred times stopping every once in a while to re-fill the reservior.
I never thought about the syringe idea. I usually just suck on the hose.
Old Aug 11, 2011 | 02:22 PM
darkember's Avatar
darkember is on a distinguished road
Just remember not to let the reservoir empty completly as that will allow air into the system. I keep on squeezing the clutch & filling the reservoir until clean fluid flows from the bleeder. An assistant would be handy for this job
Letsrideinsc
Dec 15, 2010 06:21 AM
justinity
Sep 19, 2010 04:05 PM
Sherm831
May 18, 2010 07:07 PM
merlyn
May 23, 2009 01:38 PM
HawkRider98
Sep 10, 2008 09:07 AM
