is my abttery dieing or is it something else?
Old Oct 12, 2009 | 12:52 PM
uchi's Avatar
i made apost a little while back about the bike cutting out while cranking over a few times. i havent had a chance to test the battery yet but today it did it again and when i looked down it had reset my clock and both trip meters. am i wise to invest in a new battery come spring time or is this something else?
Old Oct 12, 2009 | 01:37 PM
That's either a dieing battery or the start of a failing R/R...
Old Oct 12, 2009 | 02:11 PM
Stevebis1's Avatar
Check your charging voltage. If it is well over spec (15v+) then chances are your R/R took out your battery. If that is the case, replace both or you'll fry another battery
Old Oct 12, 2009 | 02:21 PM
VTRumble's Avatar
Check your terminals. Mine did the same thing over the summer. The negative terminal wasn't loose but needed a good cleaning.
Old Oct 13, 2009 | 05:08 PM
Red_Liner740's Avatar
^^ Same here
another problem was dimming lights as the battery wasnt there to act as a capacitor....
cleaned and tightened the contacts and shes been good ever since.
btw i had a new battery last season and Suzuki RR
Old Oct 13, 2009 | 05:17 PM
uchi's Avatar
i find when my blinker is on i can watch my lights on my display dim a little with each blink. i need to yank it out this week and test it. terminals look good, i just hardwired my batery tender and they looked clean.
Old Oct 22, 2009 | 07:33 AM
rbrais's Avatar
The quickly cutting out then running normal sounds like a bad connection somewhere. Usually when the r/r goes it is a steady problem. Ie: battery drain. That is unless it fried something.
Old Oct 22, 2009 | 02:32 PM
uchi's Avatar
yeah and now its killing the clock and trip odo when it cuts out. im gonna check the battery when i get the bike make, maybe do the rr swap over the winter.
simone
Aug 12, 2011 04:11 AM
spladle160
Nov 7, 2009 08:33 PM
codfish124
Jun 5, 2008 10:31 PM
vtrguy
May 13, 2007 08:45 PM
FRANKSVTR
Apr 27, 2006 08:37 PM
