Long distance rides
Long distance rides
I'd like to start using my bike for rides from Tx to La for fun and gas saving since my Chevy drinks a hefty 12mi/gal.
So using same chain which sprocket configurations can I use for greater fuel efficiency? 17/41 maybe?
I currently use 16/41.
Also I'd like to have a second set of wheels n tires. Which wheels are compatible with my stock hawk? Any 6" rims compatible?
I believe wheels that are pretty much bolt on, would be the CBR600 F3 F4 5.5" and CBR900's which come as 6", but you have to check if the rotors will feet. I may not have it 100% correct, it's just from what I remember at the moment
You can go with that, you may get higher top speed with that, it will take a bit longer to get there though
Just remember that you may need to cut a link from the chain if yours is already stretched to make it work.
IMO, I don't know if it is even worth the effort money wise. What you trying to save on gas you will end up spending on sprocket, labor and so on..
I usually run the freeways at high speeds so my 6th gear revs are at 6k. I'm tryin to get it down to <5k. And when I do the trips, I'll prob have a second set of wheels n tires with perm sprocket. And another set for city with bigger sprocket and stickier tires. So I'm lookin for a setup with those ideas in mind and try to use same chain. Not sure how feasible that is. But that's why I'm askin all you guys. Unless its easy to change out the chain too.
Check item number 6 combined is referred as the hub
Ronayers.com Microfiche Honda>Motorcycle>1998>VTR1000F>REAR WHEEL
You can look up your entire bike on this Ronayers site and also order directly if you wish, most people use this as reference and then get parts on Ebay or similar, but it's a good place to get OEM parts, I used it many times over the years:
You will definitely wear the chain down faster with the swap back and forth. The chain & sprockets wear together so they wont mesh as well with the city sprockets. It seems like a ton of work for very little (if any) payoff.
Why not just graduate to sport touring 2-compound tires? Harder in the middle, grippy on edge. I run only sport touring on the street since I save knee dragging for the races.
I dont know that you'll save much going taller on gearing either. The bike is very tall geared stock. In fact you may lose top speed (but who uses that) since alot of bikes actually go faster in fifth. 6th is more like overdrive.
Put a vista cruise on though. And a nice big tank bag filled with clothes to lay on.
I would leave the bike as standard and don't go throwing a K&N in there as I seen you asking about in another thread. If you want to save fuel you just have to change your riding style. Fun usually equals more (gas) money.
Carl are you kidding? Whathe lives in Texas. Them boys down there have 2 v8's in their pick-em-up trucks. Creates a wirlpool in the tank. But they dont care cuz they all have their own erl wells.
He probly goes thru 5 vtr tanks just to get out of his own county. Oh yeah, and the stars at night are big and bright __ __ __ __ ___ _____"
LOL It wasn't me that said I wanted to save gas. I think he must be kidding, as you say they have their own production lines of gas there. Who shot JR anyway
Is that La as in Los Angeles or somewhere else that I dont know off. The lowercase a has got me wondering.
Second set of wheels/spockets/chain would be WAY more expensive than just paying the extra $10 a trip you'll be possibly saving on gas. Like Joe said, you don't want to mix n match, you want to buy as a set. Lots of forces on the chain so you want to keep friction and wear as controlled as possible.
Keep the bike maintained well and get some sport touring tires...
Personally, running 16/41 would be just fine for long trips... I've done highway stints with 16/43 and it never felt out of place (and still managing 40mpg).
Ya lol well I stated how much my truck drinks. And yes, I haul some butt when cruising back to my home city/state in Laf,La. But I know I'm in sixth gear, and get a way better fuel mileage than my Z71. I'm not concerned about the costs so much as just having to stop less for fuel bc of these small tanks. I'm happy with roughly 35mpg. But I like to go fast with lower rpms. I don't wanna incriminate myself on here, so lets just say I'm typically passin folks on the interstate bc they going 'slow'. And extra wheel sets costs aren't really a factor so much. I'm using BT023's for nearly 6k miles now. Only the rear needs to be replaced soon. I want a primary set of sticky tires. BUT I hear the Battlqx S20s are really good for both, better than the bt023.
Well with that, there are a lot of wear issues with just changing rear sprocket, not to mention possible chain length problems. Just keep that in mind
You could do the VFR tank swap... it's fairly involved but looks good on the bike and will get you a bigger range without trying sprocket hocus pocus... (and will net you an extra 60 miles rather than 10 miles max with better mpg's)
Check out the tire sizes and 'acceptable rim widths' for them in the details. Surprising the 55 fits such a narrow rim. I thought fitting it onto a 5.5 was pushing it.
https://www.denniskirk.com/bridgesto...prd/543869.sku
https://www.denniskirk.com/rear-batt...re.p544159.prd
But I'll prob go with these S20's next
https://www.denniskirk.com/bridgesto...prd/544249.sku
that's pretty neat. so I did a calculation just for grins, with a 190/55 at 15/39t and its at .278% higher. That's as close to stock ratio as possible, but would that be harder on the engine?
