Increasing fuel capacity - alternatives?
Looking for input - I, like many others, want more range out of my Firestorm (or Superhawk for those of you with such
I'm not interested in spending over $1000 for a different tank that doesn't even come with a fuel cap. I'm not interested in swapping a VFR tank and doing whatever else it takes.
What about plumbing in some small fuel canisters? Has anyone done anything like this? Perhaps something along the lines of; keeping at the same level as the stock tank, plumbing into the lines after the petcock, keeping some type of ventilation/overfill system, etc. Some type of low-hassle, not-too-dorky-looking (think Law Enforcement) system would be nice.
Anyone?
PATIA!
Anyone?
PATIA!
You could plumb in additional fuel cannisters, but with the VTR not having a fuel pump, they'd have to be mounted higher than the carbs. Don't see where you could mount them except externally aka "dorky looking". And you'd probably need an additional fill cap in order to fill them unless they were both higher than the carbs and lower than the main tank petcock, which would be difficult if not impossible.
The only time I miss having a larger fuel tank is when I'm traveling in remote areas where fuel stations are few. In that case I bungee extra gas containers and a funnel on the rear of the seat.
I may just go with using some small containers instead (MSR stove canisters has been mentioned), but this would be a slick set up.
I don't see how that's a problem. If you have a vent (or something that you can open/seal) then gravity and pressure should do the rest. (it's late, so I may not have explained that well)
Slim;
If your extra fuel cannister is mounted lower than the carb fuel inlet, I don't see how gravity is going to help you get the fuel to the carbs. And when the main fuel tank is empty, what would be the source of any pressure to push it up there?
You could address that by mounting the extra supply higher than the main tank petcock, but then you'd need a separate filler cap to fill the extra container, yes?
Simplest way I've found to save fuel is put the wife on the back. Whenever we get above 70 she starts nagging. Strangely enough going below a buck save fuel. With her on back I average 42. By my self...somewhat less.
I've actually seen this done with a very small keg and line running under the seat. It works but looks pretty funky. There must be a way to fit a one gallon tank under the seat, high up, where the tool box goes and run a line to the petcock.
Two options:
Buy another bike with a bigger tank or stop and buy fuel.
I guess it really depends on your ride lengths without planning to stop. Here in the TN mountains 100 miles of twisties is enough before stopping for fuel. I would gues somewhere that is nearly flat land and longer rides a longer fuel range would be preferred.
I see no problem in our rides and road terrain with the current capacity.
what about say a tank bag with like a collapsable fuel cell in it.. kinda like a camel back hell even a few camelback plumb them in with some hose add a small on off switch, camelback already has chemical resistant bladders line insulators quick disconects. If you put these in a small tank bag you wont look like an idiot and you solve the gas over the carb problem not to mention its removable
I could sell you mine with all the CF goodies (including the huge tank) and you could transfer the parts to your bike and sell the leftover bike. You'd probably end up losing less than buying the tank by itself.
Buy the tank off a VTR wreck. Cut the top off. Shape and weld in a fillet all round (the one I've done had to have the top cut off anyway to fix the crumpling). Expanded by 5.6 litres or 1 1/2 US gallons, still looks like a standard tank. It's at the painters now.
RK1 - yes, agreed. I just wasn't wearing my thinking cap - it was on the bedpost.
The only way to get what I was thinking to work is to have a line running from a separate container, with it's own fill port and with it's own open/close switch on it's feed line to the main tank (open only once the main tank is low).
The CamelBak type idea here is intriguing. I like the MSR canister suggestion, too, (that's come up before - great minds think alike
). With this in mind .....
"Rough draft"
- container to hold gasoline above the main tank
- container is filled on it's own, separate of the main tank
- dual feed lines, each with an open/close
- feed lines are spliced into carb feed lines, right after the petcock
So my thinking here is that this type of system would work as a "re-fill" of sorts. When the main tank gets close to empty, you open the secondary container's feed lines and that fuel then flows into the main tank ..... right? I obviously wouldn't want to open the secondary container's lines until the main tank is near empty, otherwise i'd flood it (the main tank).
Am I on the right track?
PATIA!
"Rough draft"
PATIA!
use an actual plastic fuel bladder used in hobby class, gas powered, RC planes. use silicone tubing with a quick disconnect and a on/off valve. store the bladder in a camelbak brand back pack. splice it into the fuel line just before the fuel petcock. and stay the F away from any flames.
pretty much what the Marine said, just using the RC bladders instead.
that would be a bad a$$ set up.
the tank being worn like a backpack is beyond ridiculous, just a few bandannas away from being a teenage mutant ninja turtle.
hey slim, if the extra fuel bladder has a shut off valve, the the tank should have a valve plumbed into it too. then when the extra fuel bladder is being used it won't back up into an already full tank. having 2 valves will make the diff. fuel supply's to the engine independent. the tank has to vent because it is solid, but a fuel bladder just shrinks as the fuel is used. think of an IV when your in the hospital, its gravity fed just the same.
Why not just do the tail bag with as much fuel as you think you'll need...and if you run close to out B4 a fuel station...stop and fill the tank?
Me, I just annoy my riding buddies by stopping every 90 miles...
I can do an easy 330 miles before reserve with this setup...
What a great idea to use another Superhawk tank as a backpack.
It looks great and doubles your capacity.
What did you use for a fuel valve ? Doesn't the stock one dig into your lower back ?
How about the fuel sloshing around as the tank drains ?
How did you connect the two tanks ? Quick disconnect T ?
So many questions..................
Kai Ju
Kai Ju
Im with ya slim.. october im going on a ride up thru idaho and surrounding country and my dad has informed me that there are streches of 105 miles where there is only one gas station and it ends up being closed alot... now i know this is touring miles and i know ill make it but it gonna be pushing it close and it just makes me uneasy... especially the open country cuz it not like ill be doing 75
HAHAHHAHAHHAAHHAHAHAHAHHAH!!!!!!!!!
(deep breath)
HAHAHHAHAHHAHAHAHAH!!!!!!!!!!!!
That demotivational poster is AWESOME!
HAHAHHAHAHAHHAHHAA!!!!!!
Kai Ju
Kai Ju
I was actually taking the tank I picked up on ebay over to a bud's where we cut off the top, added a filler band and welded it up to add another gallon+. The accompaning pics show my painted "extended range" or "big" tank. No Honda name or logo under the clear coat; so without the OE sticker on the fairing, the only giveaway is looking at the VIN tag or side cases to know what it is. Takes me minutes to swap, as the big tank has its own fuel level sender, petcock & gas cap...
Yeah: Ed Zachary. Mine ended up much the same. You've saved me having to post a pic.
kickerfox
Jun 19, 2012 04:25 PM
j shizzy wizzy
Feb 24, 2011 07:59 PM
camelback, capacity, cf, conversion, extra, fuel, gas, hawk, increasing, level, resistance, super, superhawk, tank, valve
