I Just ordered a chain and sprocket set from sprocketcenter.com
Old Dec 28, 2010 | 09:38 PM
justinity's Avatar
Über Member
http://www.sprocketcenter.com/p/3149...00f-97-06.html
They were out of the DID 530VM chain so they are going to send the better DID 530 ZVM2 chain ( NOT THE DID 530 ZVMX )
Hopefully when the snow clears I will swap them and send pictures.
Old Dec 28, 2010 | 09:49 PM
That's the chain I installed a few months ago. Looks like you got a great deal...and cut to length as well.
Old Dec 28, 2010 | 09:58 PM
justinity's Avatar
Über Member
Yeah I know right, I was like ok when he said that.
This is what my chain looks like now.
http://tinypic.com/r/35n0f1w/7
Old Dec 28, 2010 | 10:03 PM
saige's Avatar
the boss
wow,that chain is looser than a cracked out hooker on central
did you ride it like that.
Old Dec 28, 2010 | 10:07 PM
justinity's Avatar
Über Member
On the highway 90MPH.
I am 200 pounds so It will get tighter when I sit on it, but yeah I need a new chain slider I think.
Old Dec 28, 2010 | 10:14 PM
justinity's Avatar
Über Member
And a clutch cover
Old Dec 28, 2010 | 10:17 PM
saige's Avatar
the boss
ohhhhh yea,thats nuts.did you ask anyone on here for the slider,i think some people on here had some laying around.
Old Dec 29, 2010 | 07:22 AM
Stevebis1's Avatar
Time to swap mine out also. I've been thinking this is a good time to go with a 520 conversion. http://www.sprocketcenter.com/p/6698...---honda-.html
Not sure about the chain offered in the "kit". Is there a down side to the 520ERV3? I checked out the DID site and the spec page would suggest that this "race only" chain yet the wear resitance is only about 10% under a 520ZVM-X and the tensile strength is similar.
I'm not racing, I want reasonable life so I'm staying away from aluminum sprockets. During the riding season I clean and lube my chain every 1 -2 weeks ~ 300miles. My original chain lasted 15k. I would like the new one to last that long.
Thoughts?
Old Dec 30, 2010 | 10:15 AM
justinity's Avatar
Über Member
Thoughts?
The 520 will go before the stock 530.
If you have money to experiment or if in fact you track race then I would get it.
If not I would stick with oem or better.\
I would stay with the stock setup of 530 because these bikes put a lot of load on the chain.
Old Jan 7, 2011 | 09:58 AM
justinity's Avatar
Über Member
Ok so it arrived and the quality looks bad but I may be going overboard.
I am new to this so I need to know if these sprockets are OEM or better, also if the holes in the front sprocket are going to cause problems in the future. Are JT sprockets any good, Lastly whats the stock gearing for a vtr?
I was given 16 front and 41 rear.
Size:  64.3 KBName:  6e48b484.jpg
Size:  67.1 KBName:  9e714bd7.jpg
Size:  81.1 KBName:  0abc0128.jpg
Old Jan 7, 2011 | 10:02 AM
justinity's Avatar
Über Member
Size:  72.4 KBName:  2ebc9ff6.jpg
Size:  82.5 KBName:  de2b818c.jpg
Size:  64.7 KBName:  faef01ed.jpg
Size:  117.5 KBName:  5569395f.jpg
Size:  83.0 KBName:  38c29624.jpg
Size:  77.9 KBName:  aa61c9e2.jpg
Size:  86.2 KBName:  d0f6190c.jpg
Size:  79.1 KBName:  c168f805.jpg
Size:  104.5 KBName:  cf133cfe.jpg
Size:  87.2 KBName:  1d07b2cc.jpg
Old Jan 7, 2011 | 10:32 AM
justinity's Avatar
Über Member
Are JT Sprockets any good?
Old Jan 7, 2011 | 10:35 AM
I put a JT front and a Sunstar rear on mine, and you got exactly the same chain that I have. My chain alone cost almost as much as what you paid for the set.
16/41 is stock gearing. The holes just lighten up the front sprocket a bit, no problem.
Make sure you lube the master link pins and o-rings with the little packet of grease that comes with it.
And a tip that I got from inderocker, you don't need to remove the clutch slave cylinder from the sprocket cover. Just leave the rear bolt on the slave attached, then swing it all aside and tie it out of the way.
Old Jan 7, 2011 | 11:12 AM
justinity's Avatar
Über Member
Is 102 link chain stock to?
Old Jan 7, 2011 | 12:53 PM
98VTRrider's Avatar
I liked my experience with sprocketcenter.com. I went with the DID 530ZVMX with the stealth Bi-metal Aluminum/Steel rear sprocket 16/43,
http://www.sprocketcenter.com/p/3703...t---honda.html
I like it a lot.
Old Jan 7, 2011 | 03:10 PM
Correct. It's 102 links with stock 16/41 gearing. I had to shorten mine from 120 links, so you really scored.
Old Jan 7, 2011 | 03:26 PM
majordomo490's Avatar
majordomo490 is on a distinguished road
JT are excellent, never had any problems with them.
Old Jan 7, 2011 | 10:35 PM
justinity's Avatar
Über Member
Is there a write up on here with pictures on how to remove the sprockets and chain?
Old Jan 7, 2011 | 11:09 PM
There's a lot of info on chain and sprocket replacement on threads, if you do a search. Have you downloaded the service manual? You can get the torque specs there at the very least.
First, don't bother tying the clutch lever to the grip (as the manual says) if you don't separate the clutch slave cyl from the front sprocket cover it's not necessary. Leave the rear bolt on the slave fastened. It doesn't hold the sprocket cover to the engine case.
After removing the front sprocket cover, with the bike in 1st and on the side stand, loosen but don't remove the sprocket nut. Then put the bike in neutral and raise the rear wheel for removal.
Remove the rear wheel, then remove the old sprocket. Pay attention to which side of the sprocket faces out. Also pay attention which side of the wheel the axle spacer goes on.
I used a Dremel to cut the side plates on the old chain for removal.
Remove the front sprocket and clean all the junk that has accumulated in there.
Install the new front and rear sprockets (clean the mounting surface on the rear wheel before installing the sprocket). You can torque the front sprocket nut by placing a 2x4 between the rear wheel spokes and the swing arm after installing the chain.
Install the rear wheel.
Install the chain and press the master link using the proper tool (lube the master link pins and o-rings first). The pins have to be pressed carefully to make sure the master link is secure and doesn't fly off when you're doing 100 mph.
Install the front cover with the slave cyl attached (don't forget to torque the sprocket nut). Don't forget the pushrod and don't over tighten the cover bolts.
Adjust the chain, then torque the rear axle nut.
I may have left a few details out, but that pretty much does it. I'd never changed a chain before, since all my previous bikes were shaft drive, but if you have good mechanical skills it's not that hard. Just do one step at a time.
There are also a number of videos on YouTube. Have fun.
Old Jan 9, 2011 | 09:25 AM
justinity's Avatar
Über Member
I was wondering should I replace the locking nuts that hold the rear sprocket on?
Old Jan 11, 2011 | 06:47 PM
justinity's Avatar
Über Member
Does anyone know?
Old Jan 11, 2011 | 08:09 PM
No, the nuts do not require replacement. Torque spec is 80 foot pounds.
I did them "finger tight", then tightened them to 40 ft lbs in a "star" pattern, then final torque to 80 ft lbs.
Make sure you clean the hub surface of any grease or dirt before installing the sprocket.
Old Jan 11, 2011 | 09:20 PM
justinity's Avatar
Über Member
Sweet, will do.
Old Jan 30, 2011 | 08:31 PM
justinity's Avatar
Über Member
Ok so I in installed the rear and front sprocket. Here are some pictures of the process.
Size:  96.1 KBName:  425f26cf.jpg
Size:  93.5 KBName:  81ced540.jpg
Size:  84.4 KBName:  2d4bef33.jpg
Size:  110.4 KBName:  a7fb7cc4.jpg
Size:  108.0 KBName:  e92dc801.jpg
Size:  135.6 KBName:  c1ada264.jpg
Size:  69.2 KBName:  54b3d7c6.jpg
Size:  110.1 KBName:  850f362e.jpg
Size:  109.0 KBName:  489e9904.jpg
Size:  104.9 KBName:  0c338979.jpg
Size:  136.0 KBName:  aa803cf8.jpg
Size:  132.3 KBName:  3cbe2e0c.jpg
Size:  108.1 KBName:  1adb183d.jpg
Size:  120.1 KBName:  ddf2e5b3.jpg
Size:  143.7 KBName:  37a6cb76.jpg
Size:  129.8 KBName:  4bca8869.jpg
Old Jan 30, 2011 | 08:41 PM
justinity's Avatar
Über Member
The new vortex sprocket was not a tight fit there is a minimal amount of lateral movement on the shaft.
View My Video
I found a thread on the vfr forum http://www.vfrdiscussion.com/forum/i...ront-sprocket/
I might buy the OEM drive sprocket it will keep the noise and vibration down since it has rubber buffers on both sides also fits snug.
Old Jan 30, 2011 | 08:50 PM
I hate to say it but this thread is full of fail.......
I could explain the sprocket to you but I think it would be a waste of time....
Then I would comment that most people do a bit of cleaning while things are apart, not just throw it back together dirty...
For a final comment, why put the old chain back on? Running the old chain will cause damage to the new sprockets.....
Old Jan 30, 2011 | 08:53 PM
Oh and the thread you linked...... more fail..... all aftermarket sprockets are made that way......
Old Jan 30, 2011 | 09:17 PM
justinity's Avatar
Über Member
Smile
You speak to soon, I never said in this thread that I was finished.
I took the tire off to fit the rear sprocket and cleaned it up at my house. Then I put it back on to break the front off. I'm going to clean the rest of the grime out of the sprocket cover another day it's to COLD OUT.
Old Jan 30, 2011 | 09:19 PM
justinity's Avatar
Über Member
Do you use grease on the trans splines where the drive sprocket sets, or will that aid rapid wear?
My **** was rusty as seen it the pictures.
Old Jan 30, 2011 | 10:00 PM
I have a question for you first...... in this post: https://www.superhawkforum.com/forum...&postcount=154
you claim that you have been a "Motorcycle Mechanic" for 15+ years..... so why don't you know how to put a chain on?
