How do you check to see if the front forks are straight?
Old Sep 22, 2006 | 09:24 AM
The Hawk Guy's Avatar
The Hawk Guy
Hi all,
How do you check the front forks to see if they're straight or bent? I always use my eye sights (but sometimes I don't want to believe my own eyes after a few huge wheelies). Please let me know if there are better methods to do it without taking it to the shop. Any sorts of guages or dials or any equipments, tools? Thank you!
The Hawk Guy
Old Sep 22, 2006 | 10:14 AM
Radiaoktiv's Avatar
Radiaoktiv is on a distinguished road
laser level/plumb?
Old Sep 22, 2006 | 10:50 AM
superhawk22's Avatar
You could use a square or any straight object like a ruler or take them apart and poll them on a flat surface.
Old Sep 22, 2006 | 11:11 AM
Scumbag's Avatar
Scumbag is an unknown quantity at this point
how hard are you coming down on your wheelies?
Old Sep 22, 2006 | 11:25 AM
jschmidt's Avatar
jschmidt
The proper way to check them is to dissassemble them, put them in v-blocks and measure the runout with a dial indicator. .2 mm is the maximum runout. If they are bent but not crimped, they can be straightened.
Old Sep 22, 2006 | 04:54 PM
The Hawk Guy
First gear 10'O clock wheelies and I weight about 240lbs, I doubt it if the front forks can be bent by a few wheelies, but excessive wheelies will not do any good either. Just curious to see what other people think.
I think the first symptom of excessive wheelies is fork oil leaks, correct me if I'm wrong. I’ve never seen people bend their forks by simply pulling wheelies, usually crashes, or running into something head-to-head.
Old Sep 22, 2006 | 07:57 PM
996's Avatar
996
v-twin4tmfw
996 is on a distinguished road
If you're bending your forks from wheelies then your ***** are black and blue too ! Ball Sac'n Tank slapp'n !
Old Sep 23, 2006 | 08:14 AM
JamieDaugherty's Avatar
I use a metal ruler to check them. You'll want to take them out of the triples because they usually bend right at the bottom of the lower triple. If the ruler doesn't lay perfect against the tube then you've got trouble. If it's not too bad they can be straightened, as mine were.
Old Sep 26, 2006 | 08:12 PM
apbrian112's Avatar
apbrian112
how much did they charge to get them straightened out?
Old Sep 27, 2006 | 03:34 AM
I used the Frame Man in Sacramento California. They charged me $75 to straighten one tube. It was totally disassembled, I sent them just the stanchion tube by itself.
rjm
Sep 16, 2010 12:24 PM
Forde
Aug 16, 2009 09:57 PM
mboe794
Jul 1, 2009 05:19 PM
nothing
Mar 13, 2009 09:08 AM
