headlight help
Old Nov 30, 2007 | 06:39 PM
kostavtr's Avatar
kostavtr is on a distinguished road
headlight help
hello does anyone know if there is anyway to adjust the headlights because my shine straight down it seems...thanks for the help
Old Nov 30, 2007 | 07:28 PM
make sure the bulb is seated into the headlight module securely.
Old Nov 30, 2007 | 08:27 PM
drew_c14's Avatar
ride around with the front tire about six inches in the air
Old Dec 1, 2007 | 03:28 AM
Hotbrakes's Avatar
Mine always seem to point up to the trees for some reason. I'm thinking about getting a Bat signal for it. lol
There are 2 10mm bolts behind the dash. One in the top left corner and one in the bottom right (or vice versa). If you are adjusting to move the headlight up and down, you must adjust both cause adjusting one will move the light from side to side as well as up and down. Adjusting the low beam too high is nice cause it sheds light on a lot off stuff but then the high beam will shoot right over everything so find a happy medium.
Old Dec 1, 2007 | 07:29 AM
reaper's Avatar
Make sure the light is seated properly before you push the wire clip back into place, that might be the problem.
Old Dec 1, 2007 | 02:13 PM
I thought I said that
Old Dec 1, 2007 | 04:28 PM
KC-10ENG's Avatar
Oh and by the way if you really need to get access to the bulb and stuff just pull the fairings off in one piece and take a look at it.
Dennis
CruxGNZ
Apr 30, 2015 09:11 PM
Reason
Mar 20, 2009 10:06 AM
mattvdsande
Mar 16, 2009 11:12 AM
joshuatest
Oct 27, 2008 04:44 PM
sckomar
May 15, 2005 03:24 PM
