headlight help
Mine always seem to point up to the trees for some reason. I'm thinking about getting a Bat signal for it. lol
There are 2 10mm bolts behind the dash. One in the top left corner and one in the bottom right (or vice versa). If you are adjusting to move the headlight up and down, you must adjust both cause adjusting one will move the light from side to side as well as up and down. Adjusting the low beam too high is nice cause it sheds light on a lot off stuff but then the high beam will shoot right over everything so find a happy medium.
joshuatest
Oct 27, 2008 04:44 PM
