gotta quick question
Old Jun 6, 2012 | 03:45 PM
herbvtr1000f's Avatar
herbvtr1000f is on a distinguished road
Do these bikes tend to vibrate a lot. I have a vibration between 2500-3500 when there is a load on the bike. Just thought I would ask.
Old Jun 6, 2012 | 03:49 PM
blamecanada's Avatar
blamecanada is on a distinguished road
are you loading up the throttle at that low RPM? try shifting down a gear if you need that kind of power...
thetophatflash's Avatar
Where is it felt?
Old Jun 6, 2012 | 04:02 PM
CrankenFine's Avatar
Check bar end weights for any looseness. When my left hand weight gets loose I feel a lot more vibration in the handlebar at about 3000-4500.
Old Jun 6, 2012 | 04:20 PM
red02vtr's Avatar
red02vtr is on a distinguished road
Could just be those 2 500cc pistons thumping up and down..... I know mine has a "lumpy" feel at lower rpms putting around. Its a good feeling though, not anything loose/vibrating.
Old Jun 6, 2012 | 04:53 PM
I feel it 2nd thru 4th and in 2nd between those rpm I feel it and then in 3rd it is between 3500 and 4500. I feel it between my legs and all over the bike
Old Jun 6, 2012 | 05:17 PM
Have you properly synchronized the carbs lately? Running rich? Motor mount bolts tight or too tight, rear wheel balanced, etc
Old Jun 6, 2012 | 05:26 PM
The bike is running a little rich according to the previous owner. I have not gone thru the carbs yet.
Old Jun 6, 2012 | 05:28 PM
I will go thru the bike bolts this Saturday when I have some time.
Old Jun 6, 2012 | 07:06 PM
Let me correct myself it happens from 4000-4500 1st thru 4th. Once you get past 4500 it smooths out
Old Jun 7, 2012 | 05:29 AM
nath981's Avatar
check TPS, Carb sync, valves, chain adjust/alignment, triples/bearings, tire pressure, check for loose bolts. SH ain't no in-line 4 in-terms of smoothness, but if you got everything squared away, shouldn't be annoying. Low rpms.........need to be judicious with the throttle til you get the RPMs up to 4500 or downshift
Old Jun 7, 2012 | 10:12 AM
How is the bike jetted? That is the range where you come on the needles so you might be going rich in that range.
Old Jun 7, 2012 | 11:45 AM
I have no idea how it is jetted. Previous owner jetted it
Old Jun 9, 2012 | 10:28 AM
Colors's Avatar
Colors is on a distinguished road
Mine does the same thing at lower revs, my mechanic said carbs probably need sync'd.
Old Jun 9, 2012 | 07:29 PM
mmm, somebody already suggested that...
georonimo
Oct 5, 2006 08:42 PM
Randman
Feb 23, 2006 09:05 PM
bigpat123
Dec 12, 2005 07:48 PM
W-O-T
Oct 19, 2005 08:36 AM
Dan S.
Mar 25, 2005 07:53 AM
