Frankenstand
Old Jun 18, 2009 | 07:40 PM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
Frankenstand
I've always liked the idea of one-handed or "reverse" stands, they always seemed more secure than the rear style; so when I got an old AC stick machine from a guy I work with I figured it would make a good project - up to this point my only welding experience was an afternoon playing around with various mig and tig machines at on of our suppliers. My first attempt I made adjustable L-shaped brackets on threaded rod to support the swingarm - I binned that idea when I tried welding zinc-coated hardware to steel stock! I went with a simpler 1/2" rod swingarm pin design. Initially I had the pins about 14 1/2" high - except I could'nt get the bike up even with a handle extension. I realized the tire does'nt have to be raised that high so I cut of the pins and re-welded another set at about 12 1/2" and it made all the difference. With one hand on the left grip and slight pressure on the handle it goes up on the stand no problem. 'Cause my welds are crappy I reinforced the stress points and the swingarm pins with additional 1/8" stock and 90 degree brackets. In retrospect I would probably raise the pins a little higher for a bit more clearance. Waddya think?
Old Jun 18, 2009 | 08:30 PM
Gregw's Avatar
Nice, it's funny how you can get by for so many years without a welder, then when you get one (or two), you wonder how you ever survived without. One thought on your design: The pins that the swingarm rest on may slip, causing the bike to fall. Maybe some Tool Dip on those to give them a little more friction.
Old Jun 18, 2009 | 08:55 PM
j shizzy wizzy's Avatar
mildly retarded
I'd use some rubber fuel line, or something similar to slip over those pins.
Old Jun 18, 2009 | 10:01 PM
oahu hawk's Avatar
geezer
Beautiful bike, how come you're not participating in VTR Of The Month?
Old Jun 18, 2009 | 10:11 PM
BeerHunter's Avatar
Slacker
That is a good setup that you have made. I really need to take up welding...
Good idea here. This will keep the bike from sliding for/aft while torquing bolts, prevent scoring on the bottom of swing arm, and add some extra height. The additional clearance will depend upon the thickness of the hose that you choose to install.
Old Jun 19, 2009 | 03:11 PM
Mr Toad's Avatar
Deus vult!
Thanks for the input. You can't see in the pics but I've got a piece of 1" i.d. braided hose over the pins! I don't know about bike of the month though - I just think that a red bike with white number plates is a classic look - ever since I saw Marco Luccinelli on his Duc 888 Superbike at Mosport for for the 1990 World Superbike race.
Old Jun 19, 2009 | 06:44 PM
VERY tasteful...I love the bike! Bet those staintunes sound awesome
I took a tig class about a year ago and I've been wishing to get around to getting my own and getting better at it.
Old Jun 21, 2009 | 06:29 PM
Mr Toad's Avatar
Deus vult!
Yeah, TIG welding is an art unto itself - you gotta love that "stack of dimes" look on a good tig weld, though. The build quality on the Staintunes is something else - comparable to OEM or higher. And no blown out packing!
Old Jun 21, 2009 | 06:52 PM
Reason's Avatar
Greenmeansgo!
That's pretty cool, I'd never seen that style stand before. Not to hijack, but I have the standard rear style and I can't seem to lift the bike onto it myself. Is there a safe way to do this solo?
Old Jun 22, 2009 | 09:51 AM
That's the whole point of this type of stand... Makes for a stable one man operation... one hand on the bar by the clutch, one on the stand...
The downside is the handle... It's keeps getting in the way when you work on the bike... The rear type is neater that way, but more work to use on your own...
If you are going to weld stuff up... Try an ABBA type stand... It's a one man stand and it allows the rear swing to come of, ie allows shock work...
Also combined with a small floor jack you can remove the front fork...
https://www.superhawkforum.com/forum...highlight=abba
Old Jun 22, 2009 | 10:15 AM
Well by doing it the way Mr Toad did vs bikerpiker's, the handle is parallel with the ground.. making it less in the way. In fact if you put the handle all the way at the bottom of the stand with a handle on it, it'd be even more out of the way.
Though bikerpiker's is a removable handle, so that works too.
Old Jun 22, 2009 | 10:24 AM
Well... you remove it or slip it down the tube and then there is no handle, just the stand...
