Direct replacement / swapable parts UPDATE
Old May 6, 2005 | 10:18 AM
EMetz996's Avatar
EMetz996
Fork springs –
Rachtech sells straight wound springs .75 kg/mm upto 1.0 kg/mm
Stock VTR spring rate is .58 kg/mm
VFR800 98-01 Spring rate = .75 kg/mm
SV650 Spring rate = .70 kg/mm (straight)
F2/F3 Spring rate = .65 kg/mm
Other stock springs with higher spring rate than stock VTR and are direct replacement:
Yamaha Seca II
Yamaha YZF600r
Suzuki Bandit 600
Suzuki RF600
CBR929 and CBR954 Master Cylinder
F3 Brake discs
F3 and VFR forks (will fit, but caliper mount may differ)
CBR900 Front end (we’re talking the triple tree, forks, wheel, discs, calipers)
F4i Calipers
VFR800 98-01 Bars (close fit to fairing, shims will help)
Rear brake rotor from F3, F4, CBR900, CBR929, RC51
THERES MORE, but being unconfirmed I will not post just yet!
Old May 9, 2005 | 07:33 AM
VTRDarren's Avatar
VTRDarren
929 sprockets fit... I ordered a set of 520 for the s-hawk, guy cross-referenced them to the 929 since they weren't listed for the s-hawk in 520. Fit fine.
Old Jun 18, 2009 | 12:22 PM
Rhythmbones's Avatar
Rhythmbones is on a distinguished road
Replacement Forks...
I'm curious to know if anyone happens to know where I can just a replacement forks my 03? I've seen some guys who've replace there entire front end, but it seems like that may cost more $$ than just replacing with a used/new original part.
Thoughts? Help?
Old Jun 18, 2009 | 12:33 PM
98-99 CBR900RR forks do not fit as a straight bolt-on (wider spacing and larger diameter brake rotors will require some modding).
Also, I believe that F4i calipers use the same outer casting as the RC51/929/954 models, which means that a slight bit of grinding is required to get them to fit.
Old Jun 19, 2009 | 10:01 PM
Grizz's Avatar
Carnivore
Grizz is on a distinguished road
Anyone know of any replacement mirrors?? My right one just broke!!
Old Jun 20, 2009 | 06:32 AM
chickenstrip's Avatar
chickenstrip
I believe the R1 mirrors (yr?) are direct - wait for confirmation on that though.
Old Jun 20, 2009 | 09:21 AM
Hey chickenstrip, are you really a VTR rider in NYC? I thought I was the only one with a give wing rack in the city. Mines usually on 21st st, where are you located?
Old Jun 20, 2009 | 09:22 AM
....................(GIVI).....................
Old Jun 22, 2009 | 11:39 AM
physician's Avatar
physician is on a distinguished road
just as i will be rebuildint my forks.. anyone got those vfr800 fork springs?
Rf600 are a direct swap? i have a set...lol
avramd
Dec 15, 2009 08:37 PM
nuhawk
Forum Feedback
Nov 11, 2009 03:14 PM
Rollin20z
Sep 1, 2008 06:45 AM
BiggDaddyKool
May 27, 2007 03:41 PM
Carnage
Apr 23, 2006 12:46 PM
