Fork top cap - socket size? 24mm?
Old Aug 12, 2008 | 02:20 PM
HawkRider98's Avatar
I am replacing springs and oil and it looks like the top cap takes a 24mm socket. I don't have that size and want to be sure before I go hunt one down and buy. Closest places are 40 minute drives. If anybody could verify would really appreciate. Also, jNorthWRX sold his Hawk so we probably won't be seeing too much of him but I bought Race Tech springs from him and he was great to deal with. Paid Saturday and received them today.
Old Aug 12, 2008 | 02:49 PM
filter69's Avatar
Thats Mr Dill hole to you
Well i just got the calipers on mine and it's sitting right at 23.962 MM. yup its a 24 mm socket (just put a rusty adj wrench on it )
Old Aug 12, 2008 | 02:50 PM
RK1's Avatar
RK1
Yeah. Fork caps are 24 mm, but before you drive 40 minutes realize a 15/16 socket or wrench will work fine. So would a big vice grip or pliers with some tape over the jaw teeth.
Old Aug 12, 2008 | 04:46 PM
Thanks for the confirmation. I put a 15/16 wrench on it and it wasn't quite snug enough and I was worried about rounding the edges. How snug is the cap on? I don't have any 15/16 sockets, which would give me a little more confidence in not rounding the edges.
Old Aug 12, 2008 | 05:04 PM
filter69's Avatar
the caps are orings sealed and there not very tight at all i mean you got really pissed off you could do it with your teeth... hehe just stick a adj wrench on it SNUGLY and just tap the end of the wrench on the left going to the right and it will pop right loose .... at least every friggin cap i ever took loose was basically hand tight. you may have had Bob the gorilla tighten them b4. oh it helps to loosen your clip ons b4 you try to un screw the cap....
Old Aug 12, 2008 | 06:04 PM
comedo's Avatar
The caps are aluminum. They can get messed up pretty easily if the wrench or socket isn't a good fit.
Old Aug 12, 2008 | 06:30 PM
When installing the top cap, what kind of pressure is required pushing down on the cap to compress the spring and get the threads started?
Old Aug 13, 2008 | 04:31 PM
filter69's Avatar
Well if you unscrew your preloads and take the front end off the ground(which should have already been done) its not to much force on stock springs but if you put in new ones with a bigger spacer it could get a bit rough... just make sure you get at least 3 4 therads started b4 you let go of the cap or it will strip them and possibley knock yo butt out
Old Aug 13, 2008 | 04:34 PM
Hint: Use the 15/16" if you want but use a shop towel/paper towel between the socket or wrench and the cap to prevent marring the aluminum. Those fork caps are actually aluminium (for you Brits and Aussies), kinda like unobtainium - expensive and hard to buy by themselves if buggered up.
Old Aug 13, 2008 | 06:24 PM
RK1's Avatar
RK1
Yeah, the last thing you want is to booger the aluminum fork cap. Unless somebody over torqued them down though, they come up pretty easy so if you're careful and pad the jaws vice grips, channel locks etc, can work.
The thing about a 15/16 socket is that it is nominally just slightly undersize (23.8 mm) so be sure it slides all the way down over the "nut" part and is flush with the top flat part of the cap. If it is, it will work fine.
My 15/16 twelve point socket fits perfect. I don't have one, but a six point might be tight.
niteridder64
Feb 18, 2013 10:23 AM
archaicguy
May 20, 2011 04:16 PM
fred
May 9, 2010 05:13 PM
Involute
May 7, 2008 07:11 PM
05xman
Aug 13, 2007 06:50 PM
