Foolish Question, Maybe.....
How hard would it be to loop your SH doing a 2nd gear clutch wheelie? I know it is VERY easy to loop it attempting a 1st gear power wheelie. I know it is not impossible to loop it in second, but how much effort would it really take clutching a gnarly one up for it to loop.
I know I am gonna get flamed for asking such a jackass question, but goshdamn it wheelies are fakin cool.
I cover my rear brake and can get them up but because I am so big I have to be accelerating pretty hard and slip the clutch to get them up high. Dont worry not in traffic or busy streets, and I always wear my gear too.
Alright fellas fill me in on your Superhawk hooliganism.
At first I had the biggest problem with this cause I was not using enough throttle and it would just barley come up. Mostly due to fear of the speed you are going by cracking the throttle open and trying to wheelie. For me to really pop one up I have to grab a handful of throttle and stay on it while slipping the clutch. Thus the reason for my original question about looping it.
So far I have not felt like it was in any danger of looping, but I am sure that more knowledgeable gents on this forum with more experience on the big bird may help us out.
What you are doing is correct. Get the feel for the rpm's you need to get the wheel up. Once it is up, it is all about control. For me, 4000rpm, clutch in, rpms to ~6500, clutch out while keeping on the throttle so the rpms don't drop. Wheel pops right up. Now you can ride out by keeping on the throttle but not enough to loop or you can maintain the wheelie by controlling throttle and your balance point. You can loop it if you grab too many rpm on the initial or if you are too aggressive once the wheel is up. Take your time. If you have access to a dirt bike, a couple of hours of playing around is invaluable. On my hawk, I just ride out the wheelie as I have not found the balance point.
The balance point is just before flipping. Practice, practice and practice some more, each time raising your front tire a little higher than before. You will eventually find it and hopefully before flipping it. Just remember to keep your foot on the rear brake. Once you have it down, you can ride wheelies all the way thru 6th gear as it does not take much power to keep it up in a balanced condition. Just remember that by the time you are in 5th or 6th and it starts to come down, no amount of throttle is going to keep it from coming down pretty hard. Good luck
I used to do sit down wheelies and get it to the balance point then shift through the gears. One of my friends stunts and convinced me to stand up. Standing up gives me a lot more control but I can't cover the brake cause my foot just doesn't bend like that. But with the engine braking/body positioning keeping it from going to far is easy.
My longest recorded wheelie now is 6/10ths of a mile, around a turn on the interstate. Talk about adrenaline rush! Another good thing about standing up and maintaining the balance point is I'm not going 100mph when I set it back down. I can usually maintain the speed limit and when I set it down I ROLL off the throttle slightly then jam it back on just before touch down to ease the landing. MAKE SURE YOUR WHEEL IS STRAIGHT when you land. Or you will be in for a wild ride!
Last year I was on a back road and because of the crowning of the pavement was being pushed to the ditch. So I turned the wheel to compensate and wasn't able to hit BP so I was going about 100mph when I landed which resulted in a tank slapper from hell. Luckily many years of dirtbiking took over and I just gripped the bike with my legs while maintaining throttle and let the front wheel bounce and hop and it eventually stopped. I got a steering stabilizer soon after which should minimize a similar occurence should I ever forget to straighten the wheel out.
As mentioned before, get a dirtbike and practice. Doing this on the street WILL eventually wind up in disaster when you write a check your *** can't cash.
I'm American. I believe in liberty. If you want to do wheelies, smoke crack, wear pink panties, it's OK with me. Unless and until you get in my way I don't give a ****.
That said, I don't get the fascination with wheelies at all. To me, it's "Look Ma, No Hands!" stuff. Manufacturers and MotoGP teams spend millions to PREVENT bikes from doing wheelies. If you want to **** up your front forks, wreck your steering head bearings, risk dumping your bike and getting run over by the F150 behind you, be my guest.
If somebody invented a technology which would allow me to pin the throttle in first and second without ever doing a wheelie, and that technology cost $1000 USD, I'd write the check this afternoon. Just my opinion.
I must admit, I do enjoy watching Youtube vids of you wheelie masters crashing and burning!
PS Do I do the occasional power wheelie on my VTR? Of course I do. I'm a middle aged juvenile delinquent in my own right. I love embarrassing supercharged Mustangs, Corvettes, Turbo Carreras etc. I don't know how to max out in the first two gears without lifting the front wheel. When it seems to be about 6" off the road I ease back on the throttle or short shift to the next gear. That seems to come with the territory. If I could avoid it, I would.
one of my friends can ride the balance point. like perfectly maintain the speed limit, speed up, slow down, go around corners. its frigin nutty to watch some guy cruising around on one wheel. he can sit the front down so light you wouldnt know it ever left the pavement. that said im not much into wheelies or stunting. but harping on the people that do would be like sumone harping on you for one of your other hobbies.
also if you ride, at some point your going to go down. be it from stuntin or soccer mom pullin out like you dont exist. i do agree with the practice on a dirt bike. or even a BMX bicycle. anything so that you can learn balance points.
Also I honestly don't understand how a red blooded american could NOT be fascinated by wheelies... It's the same thing as a badass muscle car with so much bloody power it can't help but shred the tires as it takes off. These bikes are so f ing powerful it shoves hundreds of pounds into the air with sheer torque. Awesome. Bloody awesome.
I wouldn't say I'm fascinated with wheelies. I do enjoy a good power wheelie while exiting a fast corner and like someone said, when an idiot in a mustang takes off hard from a light I do enjoy pulling alongside and clutching it up as I go by. If I lived in the mountains, I could ride the twisties and never do another wheelie. But I live where sixth gears turns are the norm and the odd wheelie makes up for the time between trips to track or the mountains. We are not trying to go fast when we wheelie, we are just being kids again.
A: it's called an extended swingarm. And you can have one with zero wheelies so long as you don't like turning...
It isn't so much that I'm not fascinated with wheelies. If you wanted me to practice wheelies, stoppies, burnouts etc. on YOUR bike- sign me up. I'm just not interested in abusing MY bike.
I love sixties muscle cars for the look, sound and power. Just wouldn't care much for wheelies and big burnouts if I owned one.
To me, it's like guys smashing their guitars on stage. It's their guitar, they can do what they want with it. None of my biz. Just wouldn't do it myself.
The skill I'd prefer to perfect with my VTR is not big wheelies, but how do I go from zero to 125 mph in under 11 seconds without fooking it up with a big wheelie?
I've got a '63 Gibson Firebird I paid $90 for in 1971. All original. Don't know what it's worth, don't care. If you offered me 10k for it so you could play good music on it, I might sell it to you.
If you offered me 50k for it so you could smash it and wreck it, I'd tell you to go **** yourself.
That's just me.
RK1, I could have written your last post. It's not that I'm overly materialistic, it just that things I've worked hard for (skills, experiences and the tools that provide them) have value to me. I figure if you look after things, they'll pretty much last forever. Smash 'em up, intentionally or otherwise, and you'll be shopping for that next big expense.
I asked a dealer at a recent bike show what he'd give me on a trade, and the figure was so far below the bike's continued value to me that I thanked him for allowing me to expand my stable. I will buy another bike, I just won't lose my VTR in the process. It will continue to entertain me for years.
And it's damned entertaining when that front wheel gently lifts under power!
Wheelies
Just a few things to add troops.Dont know about US but in Scotland the coppers catch you doing a wheelie on the road you have an instant ban.So if they do see you 2 options you have. Stop and be banned for a year or take the chase luckily it,s pretty easy to lose the pigs where i am but **** getting chased in US.Copper choppers on your *** in seconds is the impression i get when i watch US tv shows.So watch where you do it.And the NUMBER 1 rule always keep the rear brake covered so if your gonna flip **** that anchor on it,s better to come down with a bit of a thud than to **** your bike and back.Happy riding and keep cool
vasaq
Sep 5, 2007 06:59 PM
