difference between 98-00 and 01+?
Old Mar 12, 2011 | 02:24 PM
Alex F.'s Avatar
Alex F. is on a distinguished road
are they basically the same if it wasnt for the 01's fuel gauge??
Old Mar 12, 2011 | 02:57 PM
klu's Avatar
klu
klu is on a distinguished road
Different clutch fluid reservoir.
Old Mar 12, 2011 | 03:14 PM
Wicky's Avatar
early use regular gas - later uses premium
early has gloss finish and later models came in matt paint
Also later model has slightly different clutch cover design, tank size and bars to suit, r/r, different airbox etc,
Old Mar 12, 2011 | 03:54 PM
majordomo490's Avatar
majordomo490 is on a distinguished road
[quote=Wicky;295470]early use regular gas - later uses premium
Really? It says 86 octane in my owners book (2001)
Old Mar 12, 2011 | 04:44 PM
Alex F.'s Avatar
Major, Do u have an 01? Is it more comfortable than a 98? Bc of the clip ons or something?
Old Mar 13, 2011 | 03:49 AM
sam's Avatar
sam
sam is on a distinguished road
WHAT???? Holy crap!!! I never heard that before. So what earlier years need regular and what years need premium, and why? If I have a '99 and have been running premium, in what way or how could it effect it. ie.... run crappy or anything else?
Old Mar 13, 2011 | 06:17 AM
RWhisen's Avatar
Former Superchicken Owner
He threw that out there to see if you were paying attention. Read your owner's manual.
Old Mar 13, 2011 | 01:55 PM
Originally Posted by Wicky
Also later model has different tank size and bars to suit,
Not on North America models. They all had the same tank here.
Old Mar 13, 2011 | 01:56 PM
The ergos are the same on all models here.
There are quite a few differences between early models and the later ones.
What exactly are you looking for? The most power or the most comfort?
Old Mar 14, 2011 | 02:31 PM
OldGuy's Avatar
OldGuy is on a distinguished road
Are you sure on that? As I understand it, the handlebars changed in 2001 - the angle of the bars changed slightly to increase rider comfort.
Old Mar 14, 2011 | 03:08 PM
I have a 2001 with a Corbin seat and gen-mar risers. I'm 6'3'' and it is really comfortable. Usually do 200 miles every Saturday no problems and I have a bad back.
Old Mar 14, 2011 | 03:32 PM
Search for 53100-MBB-000ZA on a reverse part # lookup (like RonAyers) and you will see the handlebars are unchanged in all years. (description says 98-00, but it is used till 2005)
Old Mar 14, 2011 | 04:03 PM
nothing's Avatar
ride it out
is 1 fuel injected and other carb'd?
Old Mar 14, 2011 | 04:40 PM
Spaz''s Avatar
Spaz' is on a distinguished road
Post Reference this thread previously posted the other year...
dhttps://www.superhawkforum.com/forums/showthread.php?t=13982&highlight=vtr1000f01e
The above link references the previous review of this topic.
The following link will take you to the '01 Firestorm revison brochure (Aquired from: https://www.superhawkforum.com/forum...p/t-13982.html ):
http://www.burniemorgan.com/firestor...tr1000f01e.pdf
Old Mar 14, 2011 | 04:56 PM
No
Old Mar 14, 2011 | 05:00 PM
The PDF is for the euro models so I can't comment on those bikes.
They also left out the cam change.
Old Mar 14, 2011 | 05:03 PM
Alex F.'s Avatar
good stuff..thanks guys!!
Old Mar 14, 2011 | 05:04 PM
Well I guess I'll need to look at a later model one when I have a chance. He could be correct but I believe the different bars came with the larger fuel tank.
As for the part numbers, well they do the same with the cams and we have found out they are different.
Old Mar 14, 2011 | 05:09 PM
Oh and then there is the shift linkage, fairing mounting brackets and a host of small bits changed also.
Old Mar 14, 2011 | 07:00 PM
Shift linkage and Cams are 98 only I think..
Bars being moved to not hit the larger tank makes sense.. and also makes sense that because we didn't get the tank, we wouldn't get the bars.
justinity
Oct 10, 2010 10:45 AM
spladle160
Mar 15, 2010 08:42 AM
uchi
Oct 14, 2009 09:10 AM
Derty
Aug 21, 2009 07:02 AM
jserio
May 12, 2008 08:04 PM
