Could really use some help if anyone can...
Old Mar 18, 2009 | 01:20 PM
maverick's Avatar
I dropped the spring out of my petcock and I have been searching for about an hour now... I can't find it anywhere! I may need a replacement, and I was just going to grab one from the hardware store... but I need some measurements... if anyone could help that would be great.
Old Mar 18, 2009 | 04:03 PM
maverick's Avatar
Nevermind I found it. Thanks for the quick replies...
Old Mar 18, 2009 | 04:05 PM
BlackHawk996's Avatar
i support twins
no problem! i am surprised no one chimed in on this... i couldnt have help if i tried haha.
Old Mar 18, 2009 | 04:07 PM
Little_Horse's Avatar
2nd mouse gets the cheese
everyone was thinking about having to take it apart so they could give you the dims, lol. Secretly hoping some one else would step up .
Old Mar 18, 2009 | 04:08 PM
maverick's Avatar
It's ok it was a stupid mistake but I found it. However I do have a petcock question, I know it should not be on the one pointing down, but it seems like my petcock was put back together incorrectly, and it seems to run the same on both... so should it be the one all the way on the back? no matter which way it is facing... mine was facing down, now it's sideways.
Old Mar 18, 2009 | 04:26 PM
mdbuehler's Avatar
mdbuehler
Have a pic? As luck would have it my tank is on the garage floor right so I can give it a look when I get home.
Old Mar 19, 2009 | 05:38 AM
nath981's Avatar
it may run the same for a short time on either, but that will typically change down the road.
the one facing down remains open, i.e., no hose attached. the one facing to the left(close to the underside and running parallel to the underside of the tank), on the left, pointing to the left side, in line with the left fuel line, is the one that gets the vacuum line that travels along with the left fuel line.
thanks, Nathan
Old Mar 19, 2009 | 10:35 AM
maverick's Avatar
Well like I said, I already know it should be the one parallel to the ground, what I'm saying is that you can reassemble it several different ways. They are perfectly square, and there is nothing that prevents them being put back together in any direction.
This is how it was when I got the bike. Notice the one on back points down.
When I put it back together this seemed like how it should be... notice the one on back now points sideways... Which one is correct?
Old Mar 19, 2009 | 11:36 AM
the back still needs to be rotated 180 degrees
Old Mar 19, 2009 | 11:42 AM
maverick's Avatar
Well that really doesn't matter, like I said, I'm only concerned with WHICH nipple it needs to be on. I don't care about direction. Somebody just say "the nipple on the back" or "not the nipple on the back"
Old Mar 19, 2009 | 12:05 PM
one on the back has the hose
Old Mar 19, 2009 | 12:12 PM
maverick's Avatar
Thank you. So it was right in the first place.
Old Mar 19, 2009 | 05:12 PM
nath981's Avatar
so you like to play rubix cube with you p-**** huh!!
glad you got her figured out,
thanks, Nathan
Old Mar 19, 2009 | 05:26 PM
Truckinduc's Avatar
post pics of the bike man, I wanna see how its changed.
millerwl71
Jul 27, 2012 07:18 AM
kickerfox
Jun 13, 2012 06:25 PM
Zedicus
Apr 12, 2009 11:36 PM
Aviationboy
Jun 20, 2008 06:41 PM
SuperhawkWolf
Mar 29, 2007 10:44 PM
