cold blooded
Old May 11, 2009 | 06:11 PM
timdske's Avatar
timdske is on a distinguished road
cold blooded
I've been having some problems in the morning when it's the 40's or 50's. Its running rough and stumbles and misfires until it gets hot. It doesn't want to run right until its at least 70 degrees outside. When the bike gets up to 195 and up it seems to start running pretty good. I let the bike warm up in the morning I usually don't leave until it about 140 to 150 degrees. Is this pretty normal? I've always had carbed bikes but this one seems to be quarky is it a superhawk thing or what?
Old May 11, 2009 | 06:14 PM
RK1's Avatar
RK1
Once the coolant temp hits 100 degrees I can push in the choke and ride away no problem.
Old May 11, 2009 | 06:29 PM
j shizzy wizzy's Avatar
mildly retarded
mine is pretty finicky too... not quite that bad though.
Old May 11, 2009 | 07:33 PM
We rarely ride out in cold weather until the needle breaks away from the peg. Maybe check for a sticky or slow choke cable? Mine was sticking in cold weather and a shot up WD under the rubber collar was a great help. Carb Synch could be done and your jetting may be set up wrong. If your Superhawk was too rich it would bobble worse in warm weather than cold. They're all going to cackle and fart flames while they're cold on decel.
Old May 11, 2009 | 09:09 PM
Grizz's Avatar
Carnivore
Grizz is on a distinguished road
Sorry but I just have to ask. My choke will not stay out unless I hold it the entire time! When I go to start it for the first time, if I pull it out then let go it will immediately start to close killing the engine. I usually hold it open for approx 20 seconds then use the throttle to warm the bike until the temp registers prior to leaving.
I'm a little afraid to spray some WD on it as I think it will cause to to close even faster than it alread does. Any suggestions???
Old May 11, 2009 | 09:30 PM
Yeah, get over your fear.
Old May 11, 2009 | 09:43 PM
You can adjust the tension on the choke by pulling the rubber boot and adjusting the plastic ****.. a 2 second, no tool fix to keep the choke from going in on it's own.
Old May 11, 2009 | 11:12 PM
Sounds like it could be running lean on the pilot jet. Chechk to make sure there is no blockage.
Old May 12, 2009 | 06:00 PM
nath981's Avatar
Is everything stock or do you have mods? You can read my specs below. I have no problems with cold starts. I don't even let it idle but for a few minutes while I put my gloves on and drive away with the choke on full. As soon as I get past the first couple stop signs, i push the choke in and ride as usual.
Rebirth98
Oct 10, 2013 09:12 PM
twist
Jun 30, 2013 12:56 AM
Nanotech
Dec 6, 2007 07:50 AM
wyldryce
Jun 25, 2007 05:09 PM
Cheesedrug
Dec 22, 2006 05:07 PM
