Clutch slave leaking again...still...
Old Jul 30, 2019 | 04:01 PM
YMRacing's Avatar
I rebuilt it once with an aftermarket kit. It leaked. Bought all of the rebuild stuff individually from Honda and re..rebuilt it. Made sure that piston and cylinder were clean..yet again, and it started leaking after less than 30 miles. Appears to be leaking at the lower bolt gasket area. Retorqued the 8mm bolts...cleaned everything up. I did not put any gasket sealant on the gasket. Was that my mistake?
Old Jul 30, 2019 | 05:46 PM
CaryDG's Avatar
I may be mistaken but, I don't believe the gasket "Seals" anything involving the clutch (brake) fluid. It's simply just an isolator from the engine side case. Is it leaking clutch fluid or engine oil? mine leaked engine oil around the push rod seal after I disturbed it while installing my new Oberon slave. Easy fix, replaced the seal.
Old Jul 30, 2019 | 06:04 PM
YMRacing's Avatar
Unfortunately, it's indeed brake fluid.
Old Jul 30, 2019 | 11:17 PM
Wicky's Avatar
Did you check the condition of the slave cylinder bore - ingested grit can scratch the surface so much so that even new seals leak. A bit of fine grade wet&dry can help smooth things out
http://www.oberon-performance.co.uk/..._Cylinder.html
Old Jul 31, 2019 | 04:46 AM
Yeah the gasket is an isolator. Did you scour the bore? They tend to pit and become unsealable.
I went thru this a lot so got the Oberon aftermarket unit & moved on with my life.
The part just wears out and wont seal. (picture piston in gouged bore). Not worth the many afternoons of wrenching just to see it leak.
Old Jul 31, 2019 | 05:45 AM
YMRacing's Avatar
Yep, polished the piston. Cleaned the bore with a fine sandpaper finish.
Oberon sounds like the cure.
Thanks for your inputs.
Old Jul 31, 2019 | 09:19 AM
The paper gasket is there to "seal" the assembly to the case from water, dirt ect, it is not a fluid seal.
If it is indeed brake fluid and not oil, the piston to slave housing seal is likely the issue, or condition of the aluminum slave cylinder wall. If its not scratched, pitted, gouged, id take some careful measurements with an inside mic or telescoping gauge and outside mike to make sure the cylinder is round, no oval and not tapered.
Actually, no that's not true.....if I had a VTR clutch slave that needed work, id remove it and toss it in the garbage can, replacing it with a new Oberon slave cylinder and not spend a minute or dollar rebuilding a stock one
I have an early year non integrated clutch master cylinder with a fresh all service part rebuild, new res cup, SS braided line and the Oberon slave...Very happy with it. Have done the same on two other VTRs for folks, and both very happy with the results over stock.
Old Jul 31, 2019 | 04:42 PM
YMRacing's Avatar
Thanks everyone...going Oberon..anyone in particular you might recommend I purchase one from?
Found one on ebay, states it's for VTR1000RR and RC51. They claim it doesn't fit a VTR1000F....Really?
Old Jul 31, 2019 | 05:45 PM
CaryDG's Avatar
I ordered mine from Oberon-Performance.co.uk, direct. Price with shipping wasn't bad and had it in 6 days.
Old Jul 31, 2019 | 05:46 PM
superhawk138's Avatar
superhawk138 is on a distinguished road
This may be an option to buy from https://bluestreakracing.ca/us/shop-...-cylinder.html
Old Jul 31, 2019 | 06:23 PM
Originally Posted by superhawk138
Blue streak Racing is the US distributor for Oberon
You can order direct from them, though Ebay from them, or direct from Oberon.
Ive done one of each now...... really no difference
Old Aug 1, 2019 | 12:52 AM
Wicky's Avatar
The Slave unit on the VTR is common across a range of other Hondas - but the one you want is the CLU-3038
Old Aug 1, 2019 | 02:55 PM
YMRacing's Avatar
Well, I'll be damned...Without consulting with my wife, this is the second time in my life that I have made a mistake. The first was 1969. I rebuilt a VW bug engine. Being a bit of an **** retentive, and know-it-all even then, I made sure all the gaps in the rings were lined up...Now in 2019 I found that when I rebuilt my slave cylinder, I put the piston seal in backwards....Regardless, the Oberon is ordered, it will be installed soon. If you know of anyone who would like a rebuilt Superhawk slave cylinder, yes the piston seal has been <ahem> reorientated. It can be had for shipping from 61822.
I apologize for my mistake, and wasting your time...
Old Aug 1, 2019 | 07:19 PM
CaryDG's Avatar
We all make 'em! Those that say they don't, lie! LOL. You may like the Oberon better as the slightly larger bore gives it a more progressive engagement.
Old Aug 2, 2019 | 03:46 PM
YMRacing's Avatar
My wife says I'm off in the number of mistakes I've made. The 2 I confessed to are more likely a 2... with numerous zeros behind it. You're right dear.
Old Aug 14, 2019 | 03:49 PM
YMRacing's Avatar
Ordered the Oberon from Blue Streak 1 August. Arrived today, 14 Aug . Installed and, damn...I bled more than necessary as I thought I wasn't getting any clutch! It's really light! Thanks again to all of your help.
dudeitscristhian
Mar 29, 2014 09:28 PM
Shriker
Jun 27, 2013 05:35 AM
jjansenrs
May 12, 2012 05:30 AM
johnclopp85
May 6, 2009 01:55 AM
Les
Feb 4, 2006 10:28 AM
