Cleaning bike rims?
Old Apr 9, 2007 | 12:50 PM
xecutech's Avatar
xecutech is on a distinguished road
Cleaning bike rims?
I have the gold rims on my sh and they get dirty fast. What's safe to use to clean rims and not cause any damage?
Also, is there an easier way to get to those hard to reach places?
What about spray on hose off cleaner? Remember, these are the gold rims and not black.
Old Apr 9, 2007 | 02:12 PM
Thumper's Avatar
If you have lots of Chain lube build up on the rear the best way to get it off is to spray some WD-40 on a rag and clean the wheel like you were washing it. Never ever get WD-40 on the rotors or rubber of the tire.
WD-40 is pertrolium based and will remove glue, gum, bugs, Tar and other stuff.
Allways try something like this is an out of the way area to make sure it is not harming you coating. After you are done use some good car wash soap and hot as you can stand it water and wash the wheels.
Mine are stripped so i just polish mine.
DO NOT USE something like Greased Lightning or SIMPLE Green. I wouldn't use commercial Car Wheel cleaners either unless you want to first try it in a small area with a rag.
Good luck
P.S. Screw using all that expensive chain lube, just use WD-40 on your O-Ring chain, i have been diong so for 30 years and i get great chain life.
Old Apr 9, 2007 | 05:34 PM
Honda Spray Polish. Works super!
Old Apr 9, 2007 | 05:42 PM
xecutech's Avatar
To clean rims?
Old Apr 9, 2007 | 06:03 PM
SlowHAWK's Avatar
Plain old water and dish soap... although if it is gummy I will wipe it with some WD-40 first as thumper suggested... works pretty damn well... I spray it on a rag then wipe to avoid gtting it all over the rotor and tire.
Old Apr 9, 2007 | 06:12 PM
Thumper's Avatar
To clean rims?
Yea i forgot the tried and true Honda Polish, however i usually just use it on a fairly clean bike for a quick clean up.
It really depend on how nasty they have gotten on what you need to use.
I have seen some bike owners scared to wash their bikes for fear it will damage something electrical or something else.
I have owned bikes all my life and the only place i stay clear of with the water hose is the exhaust pipe opening. Everything else including the gauges get washed, never had a problem after 30 plus years of riding.
Old Apr 9, 2007 | 06:15 PM
xecutech's Avatar
Thanks for the advice. I washed the bike today, but just hosed off the rims. Hopefully, this weekend will be warmer and I can do some detailing on it.
Old Apr 9, 2007 | 06:35 PM
To clean rims?
Hell yeah! The stuff cuts through chain wax like it wasn't even there.
Old Apr 9, 2007 | 06:47 PM
Birdoprey's Avatar
Try S100 Total Cycle Cleaner. It's hard to find, might try a, gasp, chopper shop. This stuff is GOOD! Won't harm paint or plastic but cuts chain lube and brake dust like it's nobody's business.
DO NOT use car wheel cleaner. It eats the coating off Jap bike wheels.
Old Apr 9, 2007 | 06:49 PM
vtrlvr's Avatar
vtrlvr is on a distinguished road
Rims
I also have the gold rims. I waxed mine first and then once you do you that the chain lube will wipe right off and if it stuck on there thick i use chrome polish. I have found that different lube stick to the rims more so than others. Right now i am using belray. My 2 cents.
Old Apr 9, 2007 | 07:05 PM
superbling's Avatar
Yeah, read the labels. Many will say "not safe for aluminum". I found DILUTED simple green ok for powder coated wheels but heavy strenght on any bare aluminum would stain or lose its protective coating after a few washes.
Honda polish works well but pretty darn expensive as a wheel cleaner. I use it for the occasional light cleaning but use kerosene for major buildups and after chain cleaning.
If it really bothers you, get black wheels. MUCH easier upkeep.
Old Apr 9, 2007 | 07:44 PM
Nanowax cuts the grime and makes clean up next time easier. Also works good on plastics and annodized engine cases.
kai ju's Avatar
WD40 is awesome for getting sticky stuff like chain lube/wax off and is cheaper than anything else.
S100 is also available through Honda Dealers, but they call it Honda Brite, I use it diluted about 50/50 for major cleaning and use the Honda Spray Cleaner and Polish in between.
My 2 cents worth.
Kai Ju
Old Apr 9, 2007 | 08:16 PM
Corona Hawk's Avatar
Corona Hawk is an unknown quantity at this point
I have the silver rims on my Hawk and I use Oil Eater. It breaks down the lube that ends up on the kick stand and the chain guard. I also use the Honda Cleaner to clean up the rim after I lube the chain.
Old Apr 10, 2007 | 03:57 AM
shayne's Avatar
I use wax and grease remover, just like the spray painters use. Nothing better than this stuff. Not harmful to paint.
Old Apr 10, 2007 | 05:10 PM
KC-10ENG's Avatar
Spray on carnuba wax in a can. I think that the stuff that I had was made by eagle one. When I had my 92 CBR600 with the white wheels it was the easiest and the quickest thing to use. Things also came off of the wheels a lot easier after they were waxed a couple of times
Dennis
Old Apr 11, 2007 | 03:34 PM
xecutech's Avatar
WD40 knocked the grime right off! I didn't have to scrub at all. While I was down there I cleaned of some sticker residue that someone left on it and it made my bike look brand new!
I also installed a zero gravity dark smoke windscreen and it gave the bike a whole new look as well. Now all I have to do is change these stock lights out and then I am ready for some slip ons!
My wife of course doesn't agree, but she'll want something soon and then the negotiations will begin.
GeMs
Aug 31, 2007 08:27 PM
macworld
Apr 3, 2007 07:12 AM
macworld
Oct 23, 2006 01:46 AM
jtgraha2
Jun 23, 2006 11:43 AM
Carnage
Apr 23, 2006 12:46 PM
