Chain rub with rear spacer
Old Oct 17, 2017 | 07:49 PM
Does anyone else who runs shock spacers and or longer shocks have issues with the chain rubbing the exhaust under it? I may have too much ride ht but have had this issue on & off.
I recently replace the header with a used one so not sure if its out of true.
Old Oct 18, 2017 | 05:22 AM
It doesn't take mine much slack to rub the D&D's, no spacer though.
Old Oct 18, 2017 | 08:18 AM
Honda must've had an issue with it right off the bat because they put the "relief" in the left midpipe I often see mistakenly advertised as a "dent" when people are selling the stock pipes. Quite a few/most aftermarket midpipes don't have the chain relief and it doesn't take much for the chain to rub.
I'd probably cringe to do it myself but I'm sure you could flatten out the midpipe a tad in that spot and gain a little clearance (again Honda did it). Don't think you can see it and I'm sure has absolutely zero affect on power.
Old Oct 18, 2017 | 09:22 AM
If i let the chain get even a little loose (in spec but on the looser end of range) the chain will touch the pipe, more so if the suspension is not compressed at all and the chain is at its loosest point.
Old Oct 18, 2017 | 09:29 AM
superbeater's Avatar
I have TBR cans but I assume the pipe is stock. I have some thin coiled spring steel that I attached with a screw type hose clamp as a guard for the pipe. I thought the clearance issue was the result of a low side crash.
Old Oct 18, 2017 | 10:45 AM
If you have TBR cans they you'd also have TBR midpipes. The stock mid and muffler is one piece. The clearance issue is at the left midpipe.
Even with aftermarket pipes the chain shouldn't rub the midpipe. I know it's been brought up here a few times over the years with those using a spacer.
Old Oct 18, 2017 | 01:00 PM
I may just take out a spacer. I think I have 2 in now but with the 190/55 mongo ducati rear tire I don't need both.
E.Marquez
May 21, 2013 08:49 PM
Storm
Jul 2, 2010 11:45 AM
smack doogle
Oct 4, 2008 12:31 PM
superdave
Oct 27, 2006 04:39 AM
CNI Dawg
Nov 13, 2005 05:47 PM
