Banjo bolt
Old Mar 4, 2010 | 08:48 PM
spladle160's Avatar
Banjo bolt
Anyone know where I can get a dual line banjo bolt with a bleeder?
Old Mar 4, 2010 | 09:23 PM
Any of the companies that build aftermarket lines should be able to supply you with the bolt. With a bleeder? Mmmm - not sure about that one. Prob not. I think that's one you're just going to have to tough out or live with. Erik used to **** and moan about the air bubble in my brake lines. I contend it's not there and it's just the stock mc. Brakes are like chicks. Some people like grip in different areas than others. My setup will grip damn hard - almost too hard at the outset. It doesn't fade but after the intitial bite it just holds. If you pull harder and hold it down it will stoppie at a hundred.
Old Mar 4, 2010 | 10:14 PM
ranchomice's Avatar
The double banjo bolt goes at the MC right? Are you talking about the long bolt that the banjo's go onto? I've never seen a bleeder there.
Old Mar 5, 2010 | 02:15 AM
http://cgi.ebay.com/HRC-DOUBLE-BANJO...item483810c4cb
Old Mar 5, 2010 | 04:47 AM
http://www.johnstamnas.com/products/nipplesbolts.html
Any Lock Hart Phillips retailer or go on line
http://lockhartphillipsusa.x-shops.com/home.php
Dennis Kirk
http://www.denniskirk.com/jsp/produc...afCatId=&mmyId=
Old Mar 5, 2010 | 05:01 AM
And another if your still looking...
http://www.oppracing.com/show_produc...-with-bleeder/
And thanks for the reminder,, I forgot that was something I was going to pick up....
Old Mar 5, 2010 | 07:04 AM
JDRiderCoach's Avatar
JDRiderCoach is on a distinguished road
I can also get you one of these from Venhill.
Old Mar 5, 2010 | 08:03 AM
cliby's Avatar
with the bleeder the final assembly can get pretty long especially with the dual line set up. It can get pretty cumbersome and interfere wth other lines/spaces in the tight space up front. Might want to go an easier route and pick up a used newer 600/1000rr MC which has a bleeder at the MC. More compact and they can be found on ebay very cheaply. Just a thought
pbfiredawg22
Sep 8, 2010 05:48 PM
orangezuk
Aug 5, 2010 08:26 PM
peterpanic
May 18, 2010 09:00 AM
8541Hawk
Apr 30, 2008 09:07 AM
inderocker
Feb 12, 2008 09:35 PM
