Anyone have any internal Starter parts?
Old Jan 1, 2016 | 06:23 PM
thedeatons's Avatar
So i went to pull my starter off today and found extremely rusty nuts under the rubber boot (the nuts that hold the starter cable on).
I had to use an impact to get it off, but i failed to hold the stud properly and i cracked the plastic ring inside the starter housing.
Anyone have one of the plastic ring pieces?
(Note: check under your rubber boot and clean this connection!)
James
Old Jan 1, 2016 | 09:12 PM
Rick's Motorsports Brush Plate Repair Kit for Honda VTR1000 Superhawk 1988 2005 | eBay
WHole rebuild kit is pretty cheap and works great
Old Jan 2, 2016 | 01:18 AM
The nuts under the rubber boot require maintenance if you hand wash your bike or ride in the rain.
I found out the hard way like you. I check mine every couple of months.
Old Jan 2, 2016 | 10:15 AM
Hangfly's Avatar
One of long screws that holds my starter in place is seized.
It's bottomed out against the engine case like it was too long, or should have had a washer installed under the bolt head to prevent the end from bottoming out. I have no plan on attempts to remove it without snapping it off. I tried heating the case by running the bike hard and making another try. But the bolt twists and springs back as if bottomed out with corrosion at the end of the bolt area.
No hurry to remove it, yet.
Old Jan 2, 2016 | 10:16 AM
thedeatons's Avatar
The long screws hold the starter pieces together, the short screws hold the starter onto the engine. You should be able to remove the short screws and pull the starter from your bike.
James
Old Jan 3, 2016 | 05:28 PM
thedeatons's Avatar
Here are pics of the two pieces i need. If anyone has a busted starter and can part with these pieces please let me know.
Thanks!
James
Old Jan 3, 2016 | 05:29 PM
thedeatons's Avatar
Another pic of the pieces.
James
Old Jan 28, 2016 | 10:43 AM
thedeatons's Avatar
Still looking if anyone has any internal starter parts they don't need please let me know. I do not need a whole starter, would prefer to just get the parts i need from another member here.
James
1971allchaos
Oct 16, 2010 07:11 PM
nwellinghoff
Sep 27, 2008 01:48 PM
andy9743
Mar 30, 2008 12:33 PM
Rollingalong
Jan 4, 2006 07:20 PM
roadrun_fr
Aug 8, 2005 07:38 AM
