Air cleaner housing mounting screw size
Old Aug 9, 2017 | 06:14 AM
Csecrist3's Avatar
Csecrist3 is on a distinguished road
What size are the screws that hold the air cleaner housing unit to the carbs? They're the screws that connect straight to the carbs under the air funnels. I believe there are 8 total, 4 around each carb. I couldn't find what size they are in the manual nor in any of the threads on here. It's a smaller screw with a small washer. Was needing these as they are non-existent at the moment.
Old Aug 9, 2017 | 07:29 AM
Wicky's Avatar
https://www.bike-parts-honda.com/pie...IRE+STORM.html
M5 x 12
Try using a JIS screwdriver as Phillips can damage them.
JIS Screwdriver Set - Vessel Megadora P1. P2, and P3 - Rugged Roads
After I buggered up one I replaced mine with stainless hex heads versions with a dab of blue loctite to stop 'em getting sucked into the carb ;-).
A thread gauge and ruler could be a useful addtion to the toolbox to measure bolt thread and length requirements.
Nut & Bolt Thread Gauge Fraction/Metric (BLUE)
Old Aug 9, 2017 | 07:56 AM
Csecrist3's Avatar
Thanks, I'll get those this evening. Much much appreciated.
Honestly didn't even think about using calipers. Went a bit blank on that one.
Old Aug 11, 2017 | 09:25 AM
CrankenFine's Avatar
I had a complete airbox with screws on the freebies thread for over a month. Even bumped it a couple times, no interest.
It just went out with the trash two days ago...
Old Aug 11, 2017 | 09:46 AM
Csecrist3's Avatar
Didn't know there was a freebies thread or I would have tried to pick it up man.
Old Aug 14, 2017 | 02:56 PM
Do you still need these or do you have some already?
Today I found eight of these when doing some routine organizing out in the garage.
Turns out I am apparently a hoarder with Alzheimers...
Old Aug 15, 2017 | 04:47 AM
Csecrist3's Avatar
No. I went to the local hardware store and found some that were sufficient enough. Much appreciated though!
Canyon.Shreddin
Mar 26, 2016 08:10 PM
speedkelly@aol.com
May 17, 2011 02:52 PM
Fox
Dec 14, 2010 11:46 AM
supermonie
Mar 8, 2009 10:29 AM
SD996
Apr 22, 2008 09:53 AM
