Access to jets ?
Old Jan 27, 2010 | 07:52 AM
YellowBird's Avatar
YellowBird is on a distinguished road
Access to jets ?
I am doing my CCT's this weekend and while it's apart I thought I add the shims to the jets. Do the carbs have to come off the bike to do this mod? I've read the info on adding the shims but wasn't clear about having to do so. Also, are there any other adjustments needed because of adding the shims?
Thanks as always.
Old Jan 27, 2010 | 08:19 AM
RCVTR's Avatar
If i recall correctly, you need to pull the carbs off to get the front slide and needle out.
You should not need to disconnect the throttle cables, etc.
I bit of silicone lube on the boots makes installation easier. No other adjusments are needed. It will just richen the mixture a bit as the slides start to open.
Old Jan 27, 2010 | 08:21 AM
trinc's Avatar
it's easier to lift the carbs off the boots.
btw: the shim isn't for the jets, it's for the needles.
if your bike idles fine then no other adjustments are required.
tim
Old Jan 27, 2010 | 08:32 AM
YellowBird's Avatar
Thanks. I mis-wrote. But that answers it.
Old Jan 27, 2010 | 01:51 PM
nath981's Avatar
Thanks as always.
If you're going to shim needles, you may want to set the air mixture and check the TPS, and maybe some other things. Stock exhausts? PAIRS? Plug resistors? Airbox?
kinda have to practice getting the diaphrams back in. They're fragile. I forget now, but i believe I put a pencil down though the middle as you gather the spring up/compress it to keep the spring from slipping out when reassembling.
when I took all that that stuff off, i did everyhting i could do in there and I'm glad I did cause it runs much better. take your time and have fun:
Oh yeah, don't forget to set up your carbs for the easy carb sync. you'll need a fitting and a piece of vac hose from Honda and some "y" vac line fittings.
Old Jan 27, 2010 | 03:32 PM
You'll probably have to remove the "choke" cable from the front carb. Be very careful and patient when reinstalling this plastic fitting to the carb. It has fine threads that can strip easily, and I've read of others breaking the fitting by overtightening.
If you haven't done so already, you should download the manual for instructions on how to remove the diaphragm and slide assembly. There are several threads dealing with shimming the needles as well.
Old Jan 27, 2010 | 04:08 PM
RK1's Avatar
RK1
I didn't have to. I was able to go into the front vacuum chamber/needle simply by loosening the bands and pulling up the carb assembly. Didn't have to disconnect anything from the carbs.
If you're careful about it you can even get to the main jets without disconnecting the choke cable. If you disconnect everything but, you can twist the carb assembly over and remove the float bowls. At least I did.
I'll never deal with those cheese *** plastic choke nuts again unless I absolutely have to.
One other thing-
Once you've pulled up the carbs and put them back, you'll probably need to sync the carbs to make it run right.
thedeatons
Jul 15, 2015 05:24 PM
Codeblue
May 5, 2013 05:43 PM
barncat
Sep 5, 2012 06:06 PM
senecagreen
Feb 9, 2006 06:31 AM
NOrrTH
Forum Feedback
Jul 4, 2005 08:05 PM
