View Poll Results: high octain or low octain ?
high 91>+
58.33%
low 87 (cheaper)
41.67%
Voters: 24. You may not vote on this poll
87 89 91 what type of gas? Pole ((vote)) reviews...
Old May 25, 2005 | 12:45 AM
mrjakeanderson's Avatar
mrjakeanderson
I was using 91 when I 1st got the SH. Because my last I4 was recomended for high octain. but This is a V-twin not a In-line-4 (I4). So recomendations ? what do you use ?
Old May 25, 2005 | 06:51 AM
Texassuperhawk's Avatar
Texassuperhawk
Re: 87 89 91 what type of gas? Pole ((vote)) reviews...
You shoul;d still use High grade fuel in the SHawk . I run 93 in mine.
Old May 25, 2005 | 07:08 AM
icebud's Avatar
icebud
Habitually, I'm always putting 91.
There's some gas station around here that are offer 94 but with a lot of "supposed" additive to clean the engine and bla bla bla!!!! But I don't trust them on this, so I stay with the typical "super".
I think the oil to use is the most difficult choice to make!
Cheers
Old May 25, 2005 | 07:35 AM
jschmidt's Avatar
jschmidt
89
Old May 25, 2005 | 11:02 AM
NOrrTH's Avatar
Mine knocks @ low rpm using hi-test so I'm scared to use anything less than premium.
Old May 25, 2005 | 12:25 PM
mamisano's Avatar
Super Moderator
mamisano is an unknown quantity at this point
With such low compression ratio, the bike does NOT need high octane. 87/89 octane is all you need. Anything more is 1)Throwing away money 2)Giving you less performance.
Old May 25, 2005 | 12:38 PM
L8RGYZ's Avatar
http://www.handymanusa.com/articles/octane.html
mamisano's right, of course!
Read & learn. (like I did)
Old May 25, 2005 | 01:27 PM
NOrrTH's Avatar
Well what about the low rpm knock that our manual says is normal? If I used a lower octane, wouldn't it be worse?
Old May 25, 2005 | 02:08 PM
faz's Avatar
faz
faz
I use 87.
I have to use 91 in both my cars. My 2001 Miata performs better with a 91. My Mercedes knocks with anthing less than 91. They both need it.
My bikes, both ninja 250 and the SH run better on 87.
My F4i also ran better on 87 than 91.
Just my observations. Your results may vary.
Old May 25, 2005 | 02:10 PM
Hear hear Mamisano!
I started off running 91 in mine and later switched to 87 with zero problems. I have heard conflicting reports about the exact fuel requirement for the VTR but I have experienced no problems with 87.
Incidentally, I recall someone doing back to back dyno tests on a snowmobile engine (two-stroke, 2000 Ski-Doo MXZ 700) designed to run on 87 and switching to 91 LOST two hp. Given that the output of the VTR is roughly equivalent (VTR is lower by about 10-15 hp), I would expect the result to be very similar.
So, save money, increase hp, run 87 (on stock or close to engines anyhow)
Old May 25, 2005 | 08:27 PM
icebud's Avatar
icebud
Cool!!
Like we said: "the old habits have the life hard" or something like this...
Like I was always putting 91 in my previous I4, I was continuing to do it with the VTR V2, but now that means I will be able to save a couple of buck for my front end swap
I will try this right away, 170Km... I need to fuel again ?(%"/*& of small tank.
Thanks!!! the check is in the mail
Old May 25, 2005 | 08:48 PM
Thumper's Avatar
SuperHawk - 93 (is there anything else)
CB750F -93
CRF450R - 93
CR80 - 93 (plus Bel-Ray oil)
TRX250EX - 93
Miata - 87
Dakota - 87
Lawnmowers - (what ever is in the can from the last dirtbike ride - usually 93)
Old May 25, 2005 | 09:03 PM
NOrrTH's Avatar
Nice dirt bike!
Old May 25, 2005 | 09:18 PM
Thumper's Avatar
Yep yep, the CRF450R kicks A$$.
Wicked fast and got to best the fastest reving engine i have ever ridden.
Nothing like 55hp in a 230lbs bike. sounds like a vtr with half the weight and power
I so want to convert it to street in the summer months (motard) and bag to dirt fall/winter/spring
Old May 25, 2005 | 09:21 PM
NOrrTH's Avatar
Those bikes are insane. I sold my RM250 to buy my VTR. Would have loved to have kept it. Nothing more fun that rippin it up down some trail. Then again my right shoulder is still sore from when I clipped a tree.
Old May 26, 2005 | 02:01 PM
EMetz996's Avatar
EMetz996
Well, the answer has been given correctly many times. 90% of the time, we dont need to use gas octane levels above 87. The same holds true with almost all other STOCK bikes (and cars especially), regardless of compression ratio. You cant use just one number in the equation. In other words, its not just the compression ratio wich govenrns the use of higher octance. Timing, compression, wrong plugs, engine size and rpm, cam timing, even air flow design make a difference.
Try putting 87 octane in a 12:1 comp ratio inline 4 motor...try to get the thing to knock where it makes any power! Try really hard!!! The vast majority of engine knock occurs in ranges inline 4's make little power. Generally, you wont hear or need to be concerned about knock at higher RPM....in STOCK bikes.
This is topic is decades old...like oil. Use what your confortable with. If you want to pay $5 a quart for oil, and $2.50+ for 93 octance gas...so be it. Ya' aint hurt'n nut'n but'ch yo wallet...otherwise use the mainstream stuff...which is not the same as the "cheap stuff".
Old May 27, 2005 | 05:52 AM
VTRDarren's Avatar
VTRDarren
My little frame tag on the bike recommends 91. I've actually been using 89 for the last couple years, unless I'm at the track. When I finally noticed the little frame tag recommendation about a month ago I started using 91 all the time. Guess I was guilted into it, never had a prob. with the 89.
Old May 28, 2005 | 10:25 PM
mikecronis's Avatar
mikecronis
Yep, manual states 87 octane. I've played with 87, 89, and 91 and all 3 produce the same gas milage of 45mpg so far. Power-wise it -feels- that the 91 here in Denver is a little better than the 87, maybe because of a new law passed 6 months ago for emissions they're permanently using RFG gas (reformulated)?
My Pontiac TransAm Firehawk has to be adjusted and spark-advance reduced a tad for the RFG gas on the computer as the octane is slightly affected somehow.
If you consider well, it's 5800 feet altitude so you can go down a few points in octane for a carburated vehicle (SHawk) so it sort of evens-out.
I'm not sure if because of the RFG gas 91 octane is better or not. Certainly 93 octane (which is hard to find around here in Denver) is detrimental because the octane rating is too far off the recommended 87. You could probably easilly get away with 85 or 86 octane just fine, if you like sludge.
I'm pretty sure +/- 2 or 3 points of octane won't hurt. You'll want to stay within that window.
(I saw 83.5 octane in South Dakota once... no lead.)
Old May 31, 2005 | 11:01 AM
Pachucos's Avatar
Pachucos
I agree with Mamisano.
I use 85. with lower compression and the alttitude here in CO. you don't need more.
Old Jun 2, 2005 | 08:39 PM
redsuperhawk's Avatar
redsuperhawk
I run 92. All of the gas around here has at least 10% ethanol, but there are a few places around here that have pure gas at 92 octane. I've experimented with different stations, and the non-oxygenated 92 from BP/Amoco gives me the best performance.
If I could find 87-89 pure gas, I'd give it try. Ethanol sucks in the bike.
Jeff
redsuperhawk
CANADAVTR
Mar 11, 2024 12:55 PM
thedeatons
Nov 6, 2014 02:07 PM
Thumper
Jan 12, 2008 09:29 PM
Texassuperhawk
May 18, 2006 04:21 PM
