12k mile service??
Old Apr 19, 2005 | 03:00 PM
faz's Avatar
faz
faz
12k mile service??
hi all,
my bike just turned 12k miles old this past weekend.
At 8k miles, I changed the spark plugs and synched the carbs, changed rad fluid and did the oil (do that every 3k mile).
I have the manual, and will be reading through it to see the recommended maintenance. But from your experience, what is really a requirement? Any valve adjustments (if recommended by manual) is really required at this mileage??
I will be changing the air filter, and oil/filter, but that is the extend of what I was planning on doing. Anything else I should look at??
Old Apr 21, 2005 | 10:31 AM
faz's Avatar
faz
faz
Re: 12k mile service??
anyone??
Old Apr 21, 2005 | 10:59 AM
NOrrTH's Avatar
check/adjust chain? :P
I think you've covered it bud.
Old Apr 21, 2005 | 11:41 AM
faz's Avatar
faz
faz
After I typed the "anyone" comment above, I remembered that it is most likely the 16k mile service that is the recommended valve adjustment interval, and that is what I was questioning really.
For some reason, I was confusing 12k with 16k... may be due to my car running on the 12k service intervals.
Thanks, and cheers.
Old Apr 27, 2005 | 10:35 AM
faz's Avatar
faz
faz
Thanks for the heads up.
I already do all brake/clutch fulid changes every 6 monhts, and did the rad fluid already at 8k, along with spark plugs and carb synch. I change oil/filter every 3 months or 3k miles, whichever comes first, using OEM filter and full synth MX4T mobile1.
The more you maintain the bike, the better it performs for a longer time. My bike has 12k miles on it, and people who see it can't believe it is an 02.... everyone thinks it just came off of the showroom.
Old Apr 27, 2005 | 01:51 PM
NOrrTH's Avatar
faz wrote (View Post): › ‹ Select ›‹ Expand ›
I get that and mines a 98! Lets go riding sometime. I too run the Mobil mx4t.
Ashby
Same here ha ha!
ClevelandSuperhawkRumble
Mar 31, 2012 09:35 PM
mfast1
Oct 25, 2008 11:16 AM
99Hawkboy
Aug 28, 2007 08:27 PM
cb21983
Sep 6, 2006 10:53 AM
jonnykuhns
Aug 2, 2006 07:38 PM
