$50 US bounty for 6.3mm x 1.0tp bolts. Euro members?
Old Feb 3, 2006 | 10:42 PM
  #31
jschmidt's Avatar
jschmidt
You didn't read the stuff I linked, did you. Those are 1/4-20 bolts with a metric designation. When you do the measurement and add the looseness tolerance, that's what you get.
Old Feb 4, 2006 | 09:00 AM
  #33
jschmidt's Avatar
jschmidt
You must have missed something. 6.3 is a metric designation for an SAE size, part of an ISO initiative to combine the two. The looseness tolerance applied allows a 1/4-20 bolt to fit into this 6.3x1 (nominal) thread, I think.
I thought what I said was clear. Sorry if it led you to confusion.
Old Feb 4, 2006 | 04:20 PM
  #35
jschmidt's Avatar
jschmidt
My point is that there is no other correct fastener. The 1/4-20 fastener he is using isn't cut with the correct (can't believe I said that!) looseness.
They've made a machining error that won't be corrected by finding the right machine bolt.
Old Feb 5, 2006 | 03:02 AM
  #36
mdbuehler's Avatar
mdbuehler
Re: $50 US bounty for 6.3mm x 1.0tp bolts. Euro members?
Oh what fun Yup, the 1/4 20 goes in about 5 or six turns, then binds up.
I'll check with that supplier Monday, keeping in mind I need a grade 5 or higher. Running down a machine shop will have to start again Monday since I doubt any will be open today.
As the weather is going "nice" for the next week or so, I'll be putting the old front end back on the Hawk until I get this sorted. Need to ride!! Just ended the auctions for me selling them, so re-assembly starts tomorrow.
I'm in the OZ f'ed up catagory on this one. Makes noooo sense to me!
Old Feb 5, 2006 | 11:25 AM
  #37
jschmidt's Avatar
jschmidt
If you've ever used those body bolts, they do fit really loosely.
Old Feb 6, 2006 | 06:17 AM
  #38
bkelsey's Avatar
bkelsey
Makes sense. A 1/4-20 thread would have a pitch of 1.27mm, not real close to 1mm.
Old Feb 6, 2006 | 07:59 AM
  #39
kai ju's Avatar
Early in this thread I questioned whether this might be a 1/4 inch bolt but listed the pitch at 24, I have since found out that I was wrong on the pitch but also found out that 1/4 by 28 does exist.
That is a metric pitch of .907 and might just do the job for you.
Kai Ju
smokinjoe73
Mar 20, 2009 02:37 PM
jamesvtr
Apr 8, 2007 12:29 PM
Brian A
Feb 2, 2007 12:55 PM
F1 Fan in Nascar Land
Nov 29, 2006 10:34 AM
thegreep
Nov 2, 2006 09:34 PM
