my vote for a knowlegdebase add
I found this thread very informative. maybe other noobs like me would benefit from this too if it had slightly higher visibility?
Ride height spacer - Who makes em?
Currently located in the Technical Modifications area.
Thank you to all the mods for a great site. I have learned so much here my brain is on fire with ideas for cool upgrades to my new ride...
Get some washers that have an inside diameter that fits over the bolt that mounts the shock to the frame. Either lift the whole rear up and put the washers on the bolt, or do this:
https://www.superhawkforum.com/forum...ts-done-24785/
Cut the washer to slide over the bold as you lift the rear a little bit. If you look at the frame/rear shock setup, it's pretty easy to figure out where to stick the washers to raise the ride height.
Ace Hardware and Home depot make 'em.
Lifttruck
Jan 22, 2009 11:05 AM
Thumper
Jan 12, 2008 09:29 PM
mrjakeanderson
Jun 2, 2005 08:39 PM
