4 piston with 2 cylinder engine......sweet!
Old Mar 29, 2011 | 09:42 AM
j shizzy wizzy's Avatar
mildly retarded
Watch "Opposed Piston Opposed Cylinder Engine" Video at Engineering TV
pretty cool stuff.
Old Mar 29, 2011 | 10:19 AM
Good find....
Old Mar 29, 2011 | 10:27 AM
That'd be one helluva wide motorcycle!
Old Mar 29, 2011 | 10:34 AM
Very, very interesting... Good find...
Well, considering that there apparently are opposing equal forces from the dual pistons on the camshaft at all times, folding it into a V shaped engine block should be possible... Will probably look a bit odd, but should reduce width... It might actually be possible to put the two halves of that engine side by side? Making a very narrow engine instead...
Old Mar 29, 2011 | 11:35 AM
yay, 1907 technology! Opposed-piston engine - Wikipedia, the free encyclopedia
I keep seeing these pop up, they have their own issues, either two cranks, or really long connecting rods for the "far" pistons, both of which increase rotating mass and don't work well for higher RPMs.
It's not like the "force" that is held in by a normal head is lost.
Old Mar 29, 2011 | 06:29 PM
Fish's Avatar
"Now folks.......the 6 stroke engine!"
Old Mar 29, 2011 | 11:04 PM
Crower or opposed piston? I am a fan of the Crower steam cooled engine, but only to a point.. it'd be a pain to have to fill up with both gas and distilled water.
Old Mar 30, 2011 | 03:44 AM
Well, considering that the "modern" 4 stroke engine has it's roots in 1861, it's actually to be considered "new" and "hightech"...
Yeah, it's not that good for high RPM's but the proposed use in the link is for trucks and similar, so RPM's isn't an issue... Could be for bikes through...
Old Mar 30, 2011 | 09:04 AM
True.
Oddly enough the most efficient engine made is a 2 stroke diesel. (bigger than most houses) Most powerful diesel engine in the world Over 50% of the fuel burned gets turned into motion.
Simpler is often better.
Old Apr 3, 2011 | 11:56 AM
nykuryu's Avatar
nykuryu is on a distinguished road
glad someone else caught this. so 40 years later were back to prototypes again?
uchi
Sep 20, 2010 08:54 PM
skycam
Sep 10, 2010 03:35 PM
maniac2313
Feb 2, 2010 10:27 AM
sweetriden76
Oct 8, 2009 12:41 PM
superbling
May 21, 2006 08:25 PM
