wtb later model coolant temp sender
Old Apr 10, 2012 | 07:38 AM
maniac2313's Avatar
maniac2313 is on a distinguished road
i need a coolant temp sender from a newer model hawk (the smaller sensor on the tstat housing) its gotta work for the newer guage cluster...
thanks
Anthony
Old Apr 10, 2012 | 08:16 AM
Anthony, is the sender different for 1st & 2nd gen? Asking because I swapped a new motor into the old bike and everything hooked up. Wonering if its different.
Old Apr 10, 2012 | 08:33 AM
Yes, it is. They have the same part number but send different signals. Yruyur and I found that out when we upgraded his bike to the newer cluster.
https://www.superhawkforum.com/forum...cluster-18240/
Old Apr 10, 2012 | 08:45 AM
If its the same part number how can I track down the correct unit? Like I said I have an 05 motor in a 98 bike. Can I ron ayers it?
Old Apr 10, 2012 | 08:56 AM
maniac2313's Avatar
The temp sensor is the same the sender is different it looks the same different signal... there are 2a part numbers 37750-pc1-004 for earlier and 37750-kv3-951 for the later the earlier will read higher on newer cluster and newer one will read lower on older cluster...
Old Apr 10, 2012 | 08:57 AM
maniac2313's Avatar
Ill come up to you joe if youre interested in a trade...the sooner the better
Old Apr 10, 2012 | 09:12 AM
It's in the thermostat housing (not directly attached to the motor), so it depends on whether or not you switched the thermostat out when you did your motor swap.
Old Apr 10, 2012 | 10:27 AM
Ahh ok, I made this mistake before. So the sending unit has to be mated to the dash; if I have the old sender and old dash everything should be normal.
So maniac, I woulda done the swap but it wont work
Old Apr 10, 2012 | 05:06 PM
maniac2313's Avatar
Lol its cool i ordered one from indierocker and he already shipped it!!
Jack Flash
Aug 13, 2015 12:25 PM
E.Marquez
Jun 12, 2013 07:04 AM
GTS
Jun 29, 2012 09:04 PM
8541Hawk
Aug 26, 2011 03:35 PM
Kitch
Apr 25, 2007 02:31 AM
