WTB: 1999 VTR 1000F hardware - gas tank, crankshaft hole cap. front turn signals, mir
Old Aug 11, 2024 | 03:56 PM
Acecool's Avatar
Acecool is on a distinguished road
For the gas tank in question
item: 61104-422-000 - collar
item: 84703-425-000 - rubber
item: 90525-428-900 - washer
item: 96001-06028-07 - bolt
90087-KT7-000 ( Thank you xeris ) crankshaft hole cap part number - I look at left crank case cover on the website, and other but can't seem to find it.
I am also looking for one of the mirrors ( will take a pair if necessary )
MIRROR ASSY., R. BACK
88110-MBB-000
46500-MBB-D60 rear brake pedal
But if anyone has these I am interested in purchasing them!
Still have to go through to see if I have all of the hardware for the fenders, etc... But if anyone is parting one out and has the above stuff then I'd be interested in the other hardware too.
Old Aug 11, 2024 | 04:35 PM
Number 10?
https://www.ronayers.com/oemparts/a/...250/alternator
Old Aug 11, 2024 | 04:37 PM
Acecool's Avatar
Yes, that is it!! 90087-KT7-000
Thank you!
Mine is partially stripped.. I tapped a socket into it to try and get it loose but it will not budge. I'm probably going to have to chisel out a path to make sure it seats all the way and if it still doesn't budge then apply heat to the outside and get some canned air to apply cold to it. Apparently it is a common problem - I won't be torqueing it to spec in the future - under by a little bit.
Old Feb 9, 2025 | 07:16 AM
sbxhau's Avatar
sbxhau is on a distinguished road
I thought i was gonna get info on how to bypass ignition so i can use my bike after losing the keys but i ended up just getting a bunch of unrelated bs.
Old Feb 9, 2025 | 07:53 AM
Recognizing English isn't your first language, the purpose of this conversation thread is a member wanting to buy some parts. If you have a specific question, you may initiate your own conversation to ask your question and solicit an answer.
Old Feb 11, 2025 | 04:37 PM
HellsAekel
Feb 7, 2015 11:00 PM
maniac2313
May 13, 2012 08:19 PM
Matt_Hawk
Dec 2, 2011 08:27 PM
RA52426
Sep 11, 2011 04:39 AM
katryder1@gmail.com
Feb 8, 2010 01:16 PM
