For Sale Galfer Wave Rotors
Brand new in the box Galfer 320mm Wave Rotors. They are for and RC51 but should work on any SP1, SP2, and CBR600/1000RR thru 2008. $350 shipped. These do not fit stock VTR wheel, need larger diameter carrier bolt pattern.
What is the spacing and diameter of the carrier bolt holes? Also do you know the offset?
I have a wheel from a 2004 CBR1000 that I'm going to use on a SP1 fork swap. Sounds like they will fit. Want to make sure. Thanks
Diameter is @90mm interior ID, bolt spacing is 55mm, looks like the offset is 10 or 11mm, measure from base to outer edge of disc. Not sure where it needs to be measured from.
These are for an SP1 or Sp2 so it should absolutely be a bolt on. Let me know
erno Quote:
Will fit ,have same set up on my hawk f/end
