FS: Fox Shock for SuperHawk
Old Feb 19, 2011 | 10:30 AM
Moto Man's Avatar
Duc Hawk
Fox Twin Clicker Shock, fully adjustable W/ 600X900 Spring;
Recently rebuilt by Lindemann Engineering and set to 300psi
(less than 1k miles of riding on rebuild).
Purchased from Indierocker about a year ago, but never got it installed before I sold my Superhawk
I was told by Indie that this was last used on a SuperHawk by a ~260# rider about a year ago. Spring may not be ideal for that weight, but I was told it worked just fine for the rider.
This should be a bolt up, set sag, and go riding deal for someone.
$400 + Shipping
P.S. I don't have the hose clamps in the picture.
Attached Thumbnails FS: Fox Shock for SuperHawk-fox-shock.jpg
Old Feb 19, 2011 | 02:18 PM
OldGuy's Avatar
OldGuy is on a distinguished road
900 lb/in spring? Definitely NOT right for a 260 lb. rider in a VTR1000F application.
I don't have the Fox spring-rate application chart in front of me (I'm at work and the chart is at home) but I believe off the top of my head that the 900 lb/in is intended for, more like, a 160 lb rider.
I am ~185 lbs. and am using a 1000 lb/in spring on my Fox (as recommended by Traxxion Dynamics; Fox actually recommended a 950 lb/in spring for the same weight) and my spring works perfectly (measured sag backs this up).
260 lb rider would be more like a 1050 lb/in spring or 1100 lb/in spring (Fox springs come in 50 lb/in increments).
If no one else does in the meantime, I will post Fox's recommended spring rates for their shock when used on the VTR when I get home. In the meantime, here is Penske's spring selection chart (recommended spring rates would be similar): http://www.penskeshocks.com/Motorcycle-Spring_Chart.php
Btw the 600x900 shown on the Fox spring means 6.00" long x 900 lb/in rate.
Sounds like a great deal though.
Last edited by OldGuy; Feb 19, 2011 at 02:33 PM. Reason: Oooops. Removed Traxxion forkspring chart I listed by mistake.
Old Feb 19, 2011 | 02:47 PM
saige's Avatar
the boss
so from what you saying.
would this be ok for a 175lb rider
Old Feb 19, 2011 | 03:38 PM
OldGuy's Avatar
Actually, I believe a 950 lb/in spring would be more appropriate for that rider weight. That shock is a good deal; price out a separate 950 lb/in spring (springs are EASY to change on Fox Shox and require no special tools) and see if they both fall within your budget.
Old Feb 19, 2011 | 03:44 PM
saige's Avatar
the boss
If I didn't have to fix a lowside mishap and rebuild my front.
I would've try to ****** this.
Hmmmmmmm
Old Feb 19, 2011 | 05:09 PM
Kendrick's Avatar
The Hypno-Toad
Here's a somewhat random question. You mean 175 in our gear? I bet that **** ways easily 20 lbs, at least on my part.
Old Feb 19, 2011 | 05:55 PM
saige's Avatar
the boss
no,thats my regular weight.my weight goes back and forth between 170 and 175.
with clothes and gear im heavier ofcourse,so the question is do i use geared weight or regular weight.
Old Feb 19, 2011 | 05:58 PM
saige's Avatar
the boss
i just saw the chart,i guess that would be right.
Old Feb 19, 2011 | 06:12 PM
Kendrick's Avatar
The Hypno-Toad
The naked weight? Cause I'm like 170 before I get in the shower (just be glad you don't have a picture, well at least not since that Chile Peppers parody) but probably close to 200 in full gear. That could make a difference.
Old Feb 24, 2011 | 03:13 PM
OldGuy's Avatar
I just looked at the Penske spring chart and if definitely says "Rider weight with gear". I'm pretty sure the Fox spring chart was the same.
THAT makes sense as the total weight of rider gear for 2 different people can vary considerably depending on helmet, boots or shoes, jacket only or full suit, leather or textile, etc. A 150 lb rider with 30 pounds of riding gear would need the same spring rate as a 165 lb rider with 15 pounds of riding gear, for example.
Be aware, though, that Race Tech, with their spring rate selections, deals in rider weight without gear.
Old Feb 24, 2011 | 11:17 PM
Yes, obviously the shock was not setup for his weight (the forks were), but it didn't slow him down any. He's had a ton of track time along with SuperBike school training. That being said... Neil, the 260lb rider in question, could whoop my a$$ through the twisties on an clapped out '74 GL1000.
Old Feb 25, 2011 | 08:47 AM
Moto Man's Avatar
Duc Hawk
Thanks clearing that up Indie. Jamie Daugherty should be able to hook anyone up with the proper spring, for your weight, for an excellent price (http://www.daughertymotorsports.com/.../foxshock.html).
Swapping a spring on Fox Shock is super easy.
Old Feb 25, 2011 | 11:30 AM
OldGuy's Avatar
I'm actually quite surprised no one has jumped on this shock yet.
Great upgrade for a known VTR weakness (threads abound on the subject); its stock rear shock.
Last edited by OldGuy; Feb 25, 2011 at 04:20 PM. Reason: Grammar correction: its versus it's
Old Mar 3, 2011 | 01:33 PM
Moto Man's Avatar
Duc Hawk
Me too. I'm pretty sure this has to be the cheapest aftermarket shock upgrade you can get for the Superhawk. Somebody here must be in the market for a rear shock? Don't make me put this on ebay guys.
Old Mar 3, 2011 | 01:59 PM
saige's Avatar
the boss
im in the market for rear,but need front too.with the front,i can get in parts until i have everything.this is to rich for me right now.
Old Mar 3, 2011 | 02:23 PM
Once this thing sells there will be many who wished they jumped on this deal. You may be able to find a leaky one for $300, but you'll drop another $200 rebuilding it... this one's good to go!
Old Mar 15, 2011 | 04:49 PM
Moto Man's Avatar
Duc Hawk
bump for the anti-bump unit!
Must be too early in the season to sell a shock?
Old Mar 15, 2011 | 06:56 PM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
Could seriously use the upgrade for the now track-only Superhawk, but until I get "The Diamond" squared away for the GF, the funding just isn't available... rrrgh.
Old Mar 16, 2011 | 05:29 PM
Moto Man's Avatar
Duc Hawk
Priorities, priorities: Diamonds are a easy to find, but a Fox TC shock for the Superhawk isn't, and its cheaper too! Go with a CZ rock and the Fox
Old Mar 21, 2011 | 01:50 PM
Moto Man's Avatar
Duc Hawk
Spring bump for bump spring
Old Mar 22, 2011 | 04:53 PM
NooB's Avatar
I loves me twins
So what's adjustable on that sucker. Comp., rebound, and ride height?
Old Mar 22, 2011 | 05:04 PM
All of the above.
Old Mar 22, 2011 | 06:37 PM
thefitzvh's Avatar
thefitzvh is on a distinguished road
****. I don't suppose you'd want an Epiphone Les Paul custom guitar?
ROFL
I'd love to buy this. Don't have the funds.
Old Mar 22, 2011 | 07:54 PM
NooB's Avatar
I loves me twins
Moto man, pm sent.
Old Mar 23, 2011 | 10:15 AM
Moto Man's Avatar
Duc Hawk
Thanks but I don't need a Les Paul.
Old Mar 23, 2011 | 02:17 PM
Moto Man's Avatar
Duc Hawk
Just wanted to restate that this shock has not been used by me and has been recently rebuilt with very few miles on it. All you might need to do is respring it; depending on your weight.
Old Mar 23, 2011 | 05:25 PM
Moto Man's Avatar
Duc Hawk
Sale Pending to NooB
Old Mar 29, 2011 | 05:02 PM
Moto Man's Avatar
Duc Hawk
Sold!
Old Mar 29, 2011 | 06:28 PM
NooB's Avatar
I loves me twins
Damn can't wait for the new shock. Any more abuse from that pos stocker and I'd probably sterilize myself. Seriously, the little japanese ***** that test rode the first VTR must have been bouncing so hard off the seat.
EngineNoO9
Mar 16, 2007 05:26 PM
EngineNoO9
Aug 19, 2006 01:46 PM
EngineNoO9
Jul 21, 2006 07:20 PM
redline76
Jul 19, 2006 06:48 PM
cbr929rcr
Jan 7, 2005 07:27 PM
