Front end kit
Old Oct 3, 2011 | 01:32 PM
PUSHrod's Avatar
Front end kit
Offered to this forum under "right of first refusal".
From my '98 is the front end. Originally from a CBR 900 RR, it consists of both legs, the upper and lower triple, the bearings, a set of clip ons, the axle and a carbon fiber fender with the correct mounting hardware. Included are four shims that I used to make the Nissen calipers from the S'hawk fit the CBR legs while using the S'hawk front wheel and discs.
My intention is to go to e-Bay with it at the end of October if there isn't a customer for me here.
$450 plus shipping
Old Oct 3, 2011 | 01:48 PM
selztoad's Avatar
PM sent@
Old Oct 4, 2011 | 07:04 AM
davidka's Avatar
Price?
Old Oct 4, 2011 | 08:42 AM
Per the forum rules... please post a price, thanks!
Old Oct 4, 2011 | 09:12 AM
selztoad's Avatar
That is really pricey you can get a 1000rr front end for that almost
Old Oct 4, 2011 | 09:28 AM
PUSHrod's Avatar
Today the barfer site lists the 1000RR front end for $540. But I understand your position.
Old Oct 4, 2011 | 02:11 PM
selztoad's Avatar
sending money when I get off work
Old Oct 4, 2011 | 05:53 PM
davidka's Avatar
I have never seen a total bolt on conversion for so little $$ (new aftermarket clip ons can cost $200 and more). Seems like a great deal.
Old Oct 4, 2011 | 06:22 PM
selztoad's Avatar
Paid
Old Oct 7, 2011 | 07:39 PM
selztoad's Avatar
come to find out after paying its a 1998 900rr front end which doesnt work with the hawk 17 inch front wheel... so I am waiting for it to arrive to see how far off the calipers are with making complete contact with the rotors.... I am fearing the worst
Old Oct 7, 2011 | 08:46 PM
Old Oct 7, 2011 | 08:51 PM
selztoad's Avatar
Originally Posted by 8541Hawk
The 98-99 900rr rotors where 310mm and the forks were slightly farther apart, and it seems all the shims do is line the calipers up with the rotors but it does not compensate for the smaller rotor leaving part of the brake pad not making full contact with the rotor and over time the part of the pads that dont make contact with the rotor will make contact with each other
Old Oct 7, 2011 | 09:19 PM
davidka's Avatar
I guess you're past the wheel diameter problem (was only a problem for fender fit though). You could look into slightly larger rotors or just watch pad wear, it won't happen overnight and the pads are visible from the outside of the calipers. It's worth following through with the installation/use.
Old Oct 8, 2011 | 06:07 AM
(Early???) CBR1100XX rotors are a direct bolt-on to the VTR wheel (also have same offset) but are 310mm in diameter. So long as you can set the caliper offset properly, you should be good to go.
Hope this helps
Old Oct 8, 2011 | 06:42 AM
selztoad's Avatar
Hope this helps
Yea this may work but now I am out more money when I was told it is a bolt on deal
Old Oct 8, 2011 | 08:01 AM
Actually, the 97-98 CBR1100XX front rotors have a little more offset than the stock rotors.
Old Oct 8, 2011 | 09:32 AM
selztoad's Avatar
well isnt that just wonderful, I am not saying Pushrod intentionally mislead me but now i am going to be out some $$ what a pain
Old Oct 8, 2011 | 09:46 AM
Unfortunately, it's only the 96-97 edition that is a direct bolt-on (not sure about the pre-956 stuff, although I know the rotors bolt pattern is different on those.....)
Old Oct 11, 2011 | 07:16 PM
selztoad's Avatar
sent you an email PUSHrod, got my forks today and the spacers have issues along with too much pad not making contact with the rotors... i hope to get this ironed out thanks
Old Oct 11, 2011 | 07:58 PM
mertechperformance's Avatar
MandownMertech
Ouch, best of luck rectifying the issues.
Old Oct 11, 2011 | 08:07 PM
selztoad's Avatar
Sure we will work it.out
Old Oct 19, 2011 | 07:51 PM
selztoad's Avatar
and we worked it out, he refunded me partial purchase amount and all is well...thumbs up to PUSHrod! thanks
superman22x
May 24, 2015 01:35 PM
thedeatons
Nov 27, 2013 11:30 PM
mikstr
Aug 14, 2011 04:18 PM
OldHawkNewB
Mar 19, 2007 04:17 PM
Flight_996
Jan 6, 2007 04:19 PM
