Cush Drive (rubber damper) Rear Wheel
Just buy a new set for around $25
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
Pos #1
Pos #1
yep , go new.
Another discount Honda parts source
Hammond Indiana, Honda, Yamaha, Kawasaki, Suzuki, Sea-Doo, Can-Am, Polaris, Ski, Tucker Rocky, Parts, ATV, Motorcycle, UTV, Accessories, Apparel,
So it doesn't sound like a way to save money in my book as the cush drive rubbers are a lot cheaper than chains and sprockets...... IMHO
I have been running polyurethane dampers for 5 years.....two up.....riding hard.....I put 49000 miles on a set with no issues on the chain or sprockets......but what would I know I have only had 17 Super Hawks since 2006......anyway....I have sold over thirty sets no complaints........
Somewhere, maybe on this forum, I read about shimming the rubber blocks with pieces of bicycle inner tube. I happen to have a large sheet of rubber membrane used for flat roofs. Pretty similar to a tube. I've been using small pieces of that for quite some time now. May complicate reassembly of the hub to the rim though. Especially if the small strips of rubber that connect the pairs of blocks are all broken like mine are.
Anyway, it does the job. A simple, cheap way to prolong their life. My bike with 50k miles feels more "solid" than my dad's Superhawk with only 8 or 9k.
I guess for around 25 bucks, simply buying new ones isn't a bad idea either. Guess I never bothered to check the price. But sometimes I like to do things the hard way.
Millathane® 76
A general purpose polyester millable urethane rubber for abrasion resistant application
Millathane 76 is a polyester millable urethane having improved processing properties over a wide Mooney viscosity range. Compounds can be compression, transfer, or injection molded in a hardness range of 30 to 90 Shore A. Millathane 76 can be vulcanized by either sulfur or peroxide cure systems.
Millathane 76 has excellent damping properties useful in vibration control for many automotive applications. Many o-rings, seals and gaskets are made from Millathane 76 because of its excellent oil and fuel resistance. Millathane 76 is comparable to nitrile in oil and fuel resistance, but has better low temperature properties and excellent ozone resistance.
Millathane 76 can be used to replace conventional elastomers such as natural rubber, nitrile, and EPDM. Millathane 76 possesses excellent abrasion resistance combined with toughness, low temperature flexibility, ozone resistance, good damping, high tear strength and good stress relaxation properties. Such a combination of properties makes Millathane 76 a suitable choice in many applications such as bushings, small copier rolls and bumpers, o-rings, hydraulic seals, belts, solid tires, and many other high performance polyurethane parts.
So many bullies so little time....Just stating the facts......I was not "ranting".......I just happened to have some informed knowledge on the subject.......Badboyy I have New Honda dampers in factory packaging... I will send to you for free....Merry Christmas....Pm me your address and I will get them to you........As for you 8541Hawk, I did not mean to hurt your feelings....Please forgive me!.......I love the new name "partswhore"...What a novel idea and username.....I may have to use that! Where are those moderators when you need them?
Sitting back watching users make fools of them self's. This is a group of adults (who most of the time act like adults) And self moderation normally takes care of things..
For now, the only issues I see are a constant supply of
being laid into many posts
More questions on the urethane buffers
Is this the urethane product your using for your buffers?
Are they injection molded or milled from raw blocks?
Are they individual blocks?
Are they a snug fit when installed, removing all felt movement in the cush drive?
What shore are these buffers?
Pictures?
Price?
Pictures?
Price?
Millathane® 76
