Clear LED turn signals
Old Mar 11, 2008 | 08:02 PM
102dals's Avatar
Wink Clear LED turn signals
I have a set of clear LED turn signals on 'the block'...exactly like the pic. I can send more pics if you need them.
They'll definitely mount on a VTR...they were on mine about 2 months. I just didn't like the fact they're only 2 wire signals, no running lights. I definitely need the visibility here in sunny Vegas.
Wiring included to splice into existing turn signal wires, and homemade backing plates for fairing inner. Backing plates are ugly, but unseen when mounted.
$25 shipped to you (in the US). Canada or overseas slightly higher (PM & I'll check).
Old Mar 11, 2008 | 08:22 PM
Hotbrakes's Avatar
I have these too and other than not having the running light capability, I like the looks and they are bright. A good fit on the Superhawk as they cover the stock signal holes completely. Mine have connections that plug directly into the stock so no splicing.
Old Mar 11, 2008 | 08:57 PM
j_frank's Avatar
j_frank is on a distinguished road
can't they be rewired to maintain running lamps???
Old Mar 11, 2008 | 10:25 PM
Normally you can't rewire LEDs for running lights, but there are several companies out there that make separate kits to allow it. One of them is www.vfxkits.com. I have some of their stuff on both CBRs.
Old Mar 12, 2008 | 07:51 AM
Dusty B's Avatar
nOOb
Dusty B is on a distinguished road
You have any pics of these installed? Pretty sure I want them, just curious though.
Old Mar 12, 2008 | 04:46 PM
Hotbrakes's Avatar
I should have pics of mine up here tomorrow.
Old Mar 12, 2008 | 05:28 PM
Oh you so high tech! Must you use this http://www.vfxkits.com/c275229.2.html & do all 4? Per this http://www.vfxkits.com/products/uni/...anual_Rev1.pdf Or have to versus [prefer to use this instead? http://www.vfxkits.com/c215105.2.html Which may be redundent per below.
The question is can you splice from these http://www.vfxkits.com/c229412.2.html feeding the front TS and run to the rear and have running lights back there to (as I have now), or have to buy a second kit for $46 bucks?
Finally, just use their flasher and running light kit and anybody elses 2-wire LED TS?
Old Mar 12, 2008 | 06:20 PM
Gregw's Avatar
Seems like two diodes and something like a 380Ω resistor would work. Oh, and wire.
Old Mar 12, 2008 | 06:27 PM
To control the rate but not make them running lights?
Old Mar 12, 2008 | 08:02 PM
nw68868's Avatar
Certified Bad Ass
nw68868 is on a distinguished road
are they still for sale?
Old Mar 12, 2008 | 08:15 PM
Gregw's Avatar
No, to add running lights. Adding wire from the running light circuit, you’d put the resistor in line to reduce the voltage to the LED by about 60%. Then put a diode in both hot leads to keep the voltage from backing up into the other bulbs in the system, so a turn signal doesn’t look like hazard lights.
Old Mar 12, 2008 | 08:44 PM
So you don't need their flasher or does their flasher have one main diode in it? If you BYO diodes, do you need 8 diodes to do both front & back TS & running lights? Is their FX kit just 2 diodes so you need 2 kits? I'm still not clear. Would not 4 resistors (what RadioShack PN?) be required to do front & back running lights?
Old Mar 12, 2008 | 09:12 PM
102dals's Avatar
Wink
Still FS...no PMs yet. I can email pics, but not post (they're way too big).
PM me, and I'll send some.
Old Mar 17, 2008 | 04:30 PM
102dals's Avatar
Still FS. I have an interested party, but no replies after pics sent.
Old Mar 17, 2008 | 05:37 PM
Hotbrakes's Avatar
Here's a pic of these signals.
http://s33.photobucket.com/albums/d7...ent=NEWVTR.jpg
Old Mar 17, 2008 | 07:12 PM
102dals's Avatar
Mine are clear, with yellow LEDs (turn only, no running lights).
Old Mar 18, 2008 | 08:55 AM
Dusty B's Avatar
nOOb
just sent another pm to ya andy!
Old Mar 19, 2008 | 09:04 AM
Dusty B's Avatar
nOOb
Payment sent!
Old Mar 19, 2008 | 11:25 AM
102dals's Avatar
SOLD (sorry for any confusion).
Old May 8, 2008 | 11:32 AM
zangetsus_soul's Avatar
Fighting As One
zangetsus_soul is on a distinguished road
Hey who made thoes lights if i get ahold of a pair i may be able to add running light features to them by adding a seperate set of Led's
Old May 8, 2008 | 04:51 PM
Hotbrakes's Avatar
LP USA or Lockhart Phillips
johnclopp85
May 13, 2009 07:20 AM
seaton001
Mar 19, 2007 05:46 AM
iamanonymous
Sep 5, 2006 12:56 PM
CNI Dawg
Jun 8, 2006 07:28 PM
