Carb...
Old Aug 30, 2012 | 08:40 PM
Denotslaer's Avatar
Denotslaer is on a distinguished road
Carb...
Hey gang ... Been a while since ive been on , hope everyone is good . Im looking for a carb for my 76 cb 750k . Just one , I broke a stem in one of mine and it is not repairable . If anyone has one , or an old set , PM me .
Thanks a bunch !
DENO
Old Aug 31, 2012 | 05:01 PM
VtrInMtl's Avatar
VtrInMtl is on a distinguished road
Twin cam or single cam? I have a nice just-cleaned set off an 81 Nighthawk that I took apart.
Old Sep 1, 2012 | 02:15 AM
Denotslaer's Avatar
SOHC ... Not sure those will fit . My buddy has an 81 cb 750 and they are not a match. Do you have a pic ?
Old Sep 1, 2012 | 03:45 AM
Denotslaer's Avatar
Here is a pic of the carb in question.
And like I said , I just need an old body , everything else is good.
Thanks
DENO
Old Sep 1, 2012 | 01:59 PM
rr-rider's Avatar
rr-rider is on a distinguished road
Can you get the body model off the carb? I might have a spare.
and how is it broken? take a pic of the damage and maybe I can help
and the nighthawk is DOHC so that won't work.
Old Sep 2, 2012 | 05:38 PM
Denotslaer's Avatar
You are correct sir .. dohc wont work . The float stem is broken on the body.
Let me get a pic for ya , Thanks
DENO
Old Sep 2, 2012 | 05:58 PM
Denotslaer's Avatar
heres a pic of the broken stem ... as you can see , I have rigged it so the bowl doesn't overflow ... but it's shady as hell !
Pot metal doesn't weld very well !
DENO
Old Sep 2, 2012 | 08:33 PM
rr-rider's Avatar
DENO
Pot metal doesn't weld, period!
PM me and we can work something out; that post is 100% repairable!
And that looks to be the #4 body (furthest right when sitting on the bike), is that correct?
I'll rummage around to see if I have a spare body, but rest assured, it is repairable.
Old Sep 4, 2012 | 01:57 PM
Denotslaer's Avatar
Thanks rr-rider !
The post is broken on the number 3 carb , left to right. I have heard that JB weld works just fine , but havent tried it .
What do you suggest ?
DENO
Old Sep 5, 2012 | 05:15 PM
rr-rider's Avatar
Thanks rr-rider !
DENO
I don't really like JB weld because I've seen it fall apart while on a ride before. Ask me how fun it was to jerry-rig a cb360 in the mountains -_-
I've always created a new float post by drilling/tapping the body and threading a rod to go into it. Then I just cut to length, use a dremel to make a small flat where the hole in the post goes, and then drill. Takes about 20 minutes and I have never had one fail yet.
If you choose to go this route, you just need to do a little research on the best sizes and make sure to get a bottoming tap and matching dye. I use off the shelf aluminium rod to fix it and I usually add a dab of epoxy to the threads once I've verified that it functions perfectly.
Much more permanent and IMHO a much better, cleaner fix.
Thereagain, this also requires that you aren't afraid of drilling into your carburetors
