954 Lower, SP1 Upper triple w\bearings
Old Apr 9, 2010 | 09:17 PM
As I have switched to a SP1 lower triple I have a fork swappers special.
The Lower is a 954 that has been set up to use in a SH. The steering stops have been modified to clear the fairing stay and also have been drilled for extended steering stops. Right now it is set up to be used with the radiators in the stock location. If they are relocated it is just a matter of unscrewing the stops and either readjusting or removing them.
Also included is a SP1 upper triple. It is not in the best shape but is not all that bad. The Honda emblem is missing also. It does have an ignition switch also (there is a broken off key in it and I haven't messed with it to see if i can get it out)
I will also include a set of tapered steering head bearings, so it's like one stop shopping.
I'm asking $215 for everything, including shipping in the lower 48 other areas might be different.
Old Apr 9, 2010 | 11:50 PM
ranchomice's Avatar
Why are you getting rid of this stuff? I thought you were using this combo.
Old Apr 10, 2010 | 07:20 AM
Your behind the times my friend.......
https://www.superhawkforum.com/forum...ad.php?t=22113
OCMD strikes again......
Old Apr 10, 2010 | 08:36 AM
956c's Avatar
956c is on a distinguished road
dude....I was wondering why some people do things the hard way to have inverted forks....why didn't you just used the complete upper and lower system from a 954...??? it is simple..no drilling just bolt on and RIDE...
Old Apr 10, 2010 | 08:49 AM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
The issue is usually finding a complete set at something approaching reasonable pricing. They're getting more and more rare, and thus the repeated scramble to find the right assemblage of parts to work it out. It's usually cheaper to assemble a set of parts that work, and it's almost always faster than waiting on a complete setup (wheel/brake rotors, forks, triples, clipons, fender) to come up on eBay or the like.
Old Apr 10, 2010 | 11:48 AM
Syclone's Avatar
Boosted
No, it's not quite bolt on and ride. A stock 929/954 lower triple has to be shaved down in order to turn past the fairing stay... just like the OP says...
Old Apr 10, 2010 | 01:32 PM
If you just take the 929/954 triple and bolt on and ride, you are severely limited on full lock (doesn't clear the fairing stay) and once you grind that of you pinch the top coolant hose on full lock to the extent of expensive repairs in a few rides, so you add/adjust the stops... All that is done here... If you want a full CBR triple tree, get the top one separate and the lower is truly bolt & ride...
Old May 14, 2010 | 12:14 PM
Old May 24, 2010 | 02:13 PM
Price drop...... let's try $165 shipped
Old May 29, 2010 | 03:14 PM
Old Jul 5, 2010 | 02:16 PM
Old Sep 8, 2010 | 12:59 PM
Sold
Old Sep 8, 2010 | 03:59 PM
Crashrat's Avatar
Drat. I was going to ping you after tomorrow -- when I get the $$$ for the clutch cover. Ah, that's just the luck.
xeris
Mar 18, 2013 06:35 PM
8541Hawk
Mar 29, 2010 09:46 AM
8541Hawk
Mar 27, 2010 09:12 AM
KC-10ENG
Mar 9, 2007 08:19 AM
selztoad
Dec 19, 2006 07:56 PM
