Where does this vac line go to?
Old Mar 15, 2009 | 07:31 PM
nothing's Avatar
ride it out
I've got this vac line (see attached pic) that comes from behind the cage thing near the front carb on the right side, where it is tee'd off of another vac line. one end is not attached anything but i don't know where to put it but i hear it sucking. any thoughts??
Old Mar 15, 2009 | 07:37 PM
RK1's Avatar
RK1
Picture doesn't show me jack squat. Semi scientific wild *** guess? Maybe PO Teed the line off the front manifold to ease carb sync. In any case, find out where it is supposed to go or plug it.
Old Mar 15, 2009 | 07:43 PM
nothing's Avatar
ride it out
some more pics
Attached Thumbnails Where does this vac line go to?-dscn0104.jpg   Where does this vac line go to?-dscn0102.jpg   Where does this vac line go to?-dscn0100.jpg
Old Mar 15, 2009 | 08:00 PM
RK1's Avatar
RK1
OK. Looks like too fat a hose to be the front manifold vacuum line. One of those fatter hoses connects to a "T" but I can't remember what it is. Maybe somebody with a better memory will post.
Old Mar 15, 2009 | 10:21 PM
Could be vacuum sensing line for the PAIR valve. Has the PAIR been removed? It sends air to both cylinder heads near the exhaust outlet. If there is no 3/4" diameter hose going to front cyl to the right of the spark plug, behind the wheel, the PAIR has been removed.
Just plug the vacuum hose you mentioned with a small screw.
Old Mar 15, 2009 | 10:28 PM
CentralCoaster's Avatar
Should be obvious once you pull the airbox off. It's time to change the air filter anyways isnt it?
Old Mar 16, 2009 | 12:12 AM
That's exactly what it is.
Old Mar 16, 2009 | 04:13 AM
nothing's Avatar
ride it out
i have taken the air box out, but i don't know what the pair things are. any advise on how to tell if it's/they've been removed? how is it obvious by looking? and i have a new filter
caffeineracer
Jan 14, 2011 12:03 PM
scarface
Sep 5, 2008 05:23 PM
trinity012
Apr 5, 2007 02:51 PM
tommygdbr
Feb 5, 2007 05:01 AM
someonehappy
Oct 10, 2006 07:02 PM
